-   -   ICON Rezzy relocating (http://www.tacomaworld.com/forum/suspension/293864-icon-rezzy-relocating.html)
PMK 09-06-2013 03:44 AM
Curious if anyone has relocated the rezzy mounts from inside the wheelwell to a location outside the wheelwell.
I don't plan to cut through the bed or build a cage, just a simple ICON oem setup fronts 2.5 standard or extended travel and rear 2.0's.
Yes, this will involve new hoses to be made and a rebuild or fluid replacement.
Photos if you have them.
PK
Sublime 09-07-2013 02:17 AM
Why would you mount them outside? Would look funny!
The Traveler 09-07-2013 03:00 AM
I'm not sure I understand...where else would you mount them if you're not building a cage? In the cab? lol
PMK 09-07-2013 05:44 AM
Would like to move the rezzyz for the rears to the inside of the frame rails.
The fronts would also move inside the frame rails, and possibly across the front near the bumper mounting location.
Just want to make them a bit less obvious and provide them more protection from debris off the tires.
PK
The Traveler 09-07-2013 11:37 AM
PK
But resi's pull bitches...why would you want to hide them?? :confused:
At any rate, I don't see why you couldn't mount them inboard. Would need to pretty much disassemble and recharge the shocks to change hoses though. If I wanted to hide them, I'm wrap them in electrical tape or spray paint them black.
PMK 09-07-2013 05:15 PM
After being married for 28 years, I have learned girls are nothing but trouble, and bitches come with baggage.
Not really need to hide them, more so than get them away from the abuse of debris kicked up from the tires.
PK
