Help... SAWs rubbing on sway bar!
Discussion in 'Suspension' started by jrloTACO, May 16, 2009.
  1. May 16, 2009 at 9:00 AM
    jrloTACO
    jrloTACO [OP] Member
    hey gang... here's my dilemma. i just had SAWs coilovers installed. i noticed some squeaking so i looked underneath and on the driver's side (passenger side is fine), i found that the coil is butted right up against the sway bar. so i put some grease and that fixed the problem, no more squeaking.
    but i figure the grease will rub away eventually, so i need a permanent fix. i'm thinking i need new sway bar end links.
    anyone have any recommendations where i can get these?
    oh, i have a 2009 TRD Sport 4x4 DC LB.
    thanks all!
    jason
  2. May 16, 2009 at 9:20 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Try Toytec Lifts...They have a "relocate" kit. Some spacers to move the sway bar brackets away from the coils...
  3. May 16, 2009 at 11:49 AM
    jrloTACO
    Sweet I'll check them out. Thanks.
  4. May 16, 2009 at 11:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No prob...I hope they will fix your rubbing issue!!
  5. May 16, 2009 at 1:15 PM
    dabighi
    dabighi Well-Known Member
    ya i noticed the same issue with my procomp kit. im just gonna relocate the sway bar.if i remember correctly the guys at icon told me id have to just forgot
  6. May 16, 2009 at 1:25 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    i have saw's with the relocate kit and it rubs on drivers side, fixed yesterday by takeing the sway bar off, soo much better.
  7. May 17, 2009 at 7:15 AM
    jrloTACO
    this is what i ordered from toytec: hopefully this will resolve the issue.
    bajamoon, i don't think removing the swaybar is a good idea, right? doesn't that detract from handling performance?
  8. May 17, 2009 at 7:22 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You'll get more body roll and sway during driving...but you CAN do it...It's personal preferance really...I wouldn't want to drive a lifted truck without one....but people do ::shrug::
  9. May 17, 2009 at 8:08 AM
    bajamoon
    STEVE
    Whittier
    hey brunes have tried it, i waited a long time before i took it off, tested it getting on the freeway on ramp and not that bad, my 05 f150 had more body roll.
  10. May 17, 2009 at 11:22 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Some people like the softer feel. I have a scion tC in my drive way too...and that thing feels like it's on rails compared to the truck...and I still want to install a strut tower bar in front, strut braces in back, and an upgraded sway bar kit. I REALLY like stick to the road.
    It's a personal choice...I like them...but it's all about what you are comfortable with I guess...
  11. May 20, 2009 at 10:20 PM
    dabighi
    ya im not a big fan of the body roll.ordered the relocation kit from toytec. like 30 bucks all together. only problem is im at the station the next 3 days so i cant install it yet. guess good thing is that i wont have to drive while im at the station either.
  12. May 21, 2009 at 6:42 AM
    bajamoon
    STEVE
    Whittier
    the relocater kit did not help mine at all, it would still rub the coilover.
  13. May 21, 2009 at 9:35 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    do SAW still carry their replacement sway bar? i know when the c/o first came out they included a sway bar with the coilovers but then switched to the relocating kit later on
  14. May 21, 2009 at 10:18 AM
    bajamoon
    STEVE
    Whittier
    don't know, i have not seen it.
  15. May 21, 2009 at 10:29 AM
    tacoskim
    Los Angeles, CA
    Stock
    This is what came before the relocating kit
  16. May 21, 2009 at 1:39 PM
    ldanny
    ldanny Well-Known Member
    i just got back from camburg and got the kit.. it was only $20. So if you are in Socal, just drop by there.
  17. May 21, 2009 at 5:10 PM
    bajamoon
    STEVE
    Whittier
    got my sway bar relocater kit free with my coilovers, it is supposed to come with the kit, if i still have mine someone can have it, i might have tossed it.
  18. May 22, 2009 at 4:48 PM
    dabighi
    anyone have any pictures or info on how the relocator goes on. pretty sure i know how its supposed to be just wanna make sure
  19. May 22, 2009 at 4:52 PM
    bajamoon
    STEVE
    Whittier
    it will only fit one way, goes in the stock location you can't put it in backwards, i tried.
  20. May 22, 2009 at 5:46 PM
    fastprostreet
    fastprostreet Well-Known Member
    Pete
    Ohio
    I had this same problem with Sway a Ways rubbing the sway bar last summer when I installed them on my 2008. Everyone I talked to at Sway a Way acted like they never heard of the problem - yea right. I see they haven't redesigned their shock to eliminate the problem.
    I fixed the problem by sending the Sway a Ways back and installing a set of 2.5" Icons. Problem solved.
