-   -   Toytec Lift Questions (http://www.tacomaworld.com/forum/suspension/3877-toytec-lift-questions.html)
Big Guns 11-09-2007 12:33 PM
Okay, so i know there are a lot of threads about the toytec 3" lift out there, but ive spread around some questions and just decided to consolidate to one thread...
:confused::confused:
I am looking at the 3" pro basic and coil lifts. What are your opinions vs. either? I figre the coil setup would give me a better ride, but is it worth the couple extra bucks? What is the more popular of the bunch.
AAL or Block?
How is ease of install? Im somewhat mechanically inclined, but i dont know what goes into the install and dont want to get in over my head halfway through ripping apart my front end. I dont have a coil compressor so would i need that if i opt for the spacers instead of the coilover?
I know its a lot of quesitons, but i have never done much research on a spacer lift, always looking at big time suspension lifts so this is all somewhat new to me. I appreciate any feedback/comments you guys have.
Thanks!
Toy4Life 11-09-2007 12:53 PM
I don't know much about the coil lift. I have a spacer lift on order.....should be at my house on Teusday. From what I understand, the spacer lift at least, requires only basic tools and knowledge + the coil compressor. Most of the chain part stores have loaner programs where you could borrow the compressor. I believe Toytec recomends the AAL as opposed to the block.
There is a section on the Toytec site with FAQ. If you havn't checked that out, there is some good info there.
Big Guns 11-09-2007 01:11 PM
Ill check it out. Thanks.
Toy4Life 11-09-2007 01:26 PM
I'm no mechanic, but I am completely confident that the install will go smoothly in my driveway.
crewchief97 11-12-2007 06:06 PM
I did the front spacers in my driveway by myself in approx 4 hours and I have the AAL leaf in the back. The instructions for the spacer install where pretty good, on the other hand the rear was not. In my opinion, the AAL was more of a pain in the backside to install. According to the instructions, you can install the extra leaf without removing the rear spring, I could not. I ended up just removing the rear spring completely. Good luck with your install and an impact gun (elec or air) will greatly speed up the spring compressing.
-Brian
LQQKatmy06 11-12-2007 06:31 PM
IMO coils will give a better ride, the coils and spacer is the same process. Go with the AAL it wont cause axle wrap and adds more payload. It's not that hard of a install. You can get 4" on your Prerunner with new spindles.
Toy4Life 11-12-2007 06:41 PM
-Brian
Funny you should mention the difficulty of the rear. I've read the instructions several times and the AAL seems like the more difficult part.
I do have an air compressor and an impact gun and my buddy's gonna bring his coil compressor and give me a hand.
I'm a little bummed that I'm gonna have to just sit on the lift for a couple weeks before I'll have the free time to do the install.
I'll post pics once it's done.
L_Jackson 11-12-2007 09:16 PM
I did the Toytec 3" inch lift with the spacer in the front and the AAL.... here are my thoughts:
The front took me about 8 hours in my garage with no help.... the compressing the springs was the most aggrivating part. (i have a small write up with more details) two people should knock it out a lot quicker....
the AAL took about 1.5 hours at a buddy's house. i could not do it at my house because we needed some really big jacks and jack stands. after doing the lift on the front end my frame was too high in the air for any of my jacks. I thought it was a lot easier than the front.
more details are at:
http://www.tacomaworld.com/forum/sus...-lift-kit.html
MarkC 11-13-2007 02:20 AM
for a prerunner i would go with just the spacer, my old supervisor did the toytec springs and his trucks rides just the same on road and even on mild trails. no need to spend xtra money if your really never goin to use it,
Delrivpilot 11-13-2007 04:17 AM
For what it's worth, I just added the Toytec 2" spacers in front and had the TSB suspension done. It leveled out the truck and lifted it just enough. Toyota even installed the spacers.(for $140)
Toy4Life 11-13-2007 01:00 PM
I've seen some insight into the Toytec install on the 2nd gen Tacomas and appreciate the posts regarding them, but does anyone have any tips, tricks, or things to watch out for on the 1st gen.
I'll be installing the 3" spacer/AAL w/ProComp extended rear shocks and the diff. drop on my 02 v6 TRD 4x4. I know this will be similar to the 2nd gen, but it's not identical as far as the installation process.
thanks guys.
350TacoZilla 11-13-2007 04:41 PM
the toy tec lift i had before made alot of noise on a 1st gen like the coil must not seat well or something... maybe it was a flaw that is gone by now
