Trimming Pictures
Discussion in 'Suspension' started by cantac09, Jun 3, 2009.
  1. Jun 3, 2009 at 4:48 PM
    cantac09
    cantac09 [OP] Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    Hi
    I have just installed a 3 inch lift on my 2009 trd and my installer said i have to trim to fit my 285/70/17 goodyear duratracs and he wouldnt do it for me and i was wondering if anyone has pictures of where they trimmed.
    Thank you in advance!
  2. Jun 3, 2009 at 5:36 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Towards the cab I had to trim slightly. Now that I have removed the swaybar and installed new UCAs I have trimmed more.
    In the front the big square nub.
    Here I cut some and zip tied it back to make sure it doesn't move.
  3. Jun 3, 2009 at 5:38 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    thank you very very much
  4. Jun 3, 2009 at 5:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Not a problem. All the trimming was done with a razor knife. I actually just trimmed some more yesterday.
  5. Jun 3, 2009 at 5:40 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    is it pretty difficult to do and is it different for everyone where they have to trim
  6. Jun 3, 2009 at 5:43 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Should only take 10 minutes if you go slow as to not cut yourself. Pretty similar for all our trucks, however depending on tires (their sizes differ) some rub more than others. Turn your wheel as hard as you can to one side to see where to cut, then turn in the opposite direction and trim there.
  7. Sep 19, 2009 at 2:39 AM
    Poke Tako
    Poke Tako Mall CRAWLer.
    2017 TRD Offroad 4x4
    I went to Les Schwab to install my Tuff Country suspension lift, 285/75 Toyo M/T, and Spidertrax wheel spacers. They provided excellent customer service by trimming for free on areas that rubbed. They did a good job at it with no rubbing issues.
