FOX 2.0 vs 2.5 Coilover
Discussion in 'Suspension' started by Seagrave, Jun 7, 2009.
If you had a choice and money wasn't a factor, would you choose...
  1. Fox 2.0 adjustable coilovers
    24.6%
  2. Fox 2.5 coilovers
    75.4%
  1. Jun 7, 2009 at 5:06 PM
    Seagrave
    Seagrave [OP] Well-Known Member
    2009 DC LB 4x4 Sport
    :help:
    I apologize in in advance but I was unable to find my answer in the other suspension threads and tried a searching for it too.
    This information will help others too.
    I have several suspension questions...
    I have narrowed it down to FOX brand suspension products for the lift on my 2009 Tacoma (4 door Long Bed 4x4)
    What is the difference between the Fox 2.0 and the fox 2.5? What does the 2.0 and the 2.5 mean. Is that the diameter of the spring or the shock? :notsure:
    Also, why is the 2.0 Fox Coilover cheaper if it has adjustability to it?
    If you have a choice, which one would you get, the 2.0 or the 2.5 Fox Coilover?
    Also if you have pictures of Fox products... lets see ONLY fox suspension here too
  2. Jun 7, 2009 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    2.0 and 2.5 refers to the diameter of the shock body. The 2.5 holds more oil, so as to stay cooler longer. Depending on the wheeling you do, the 2.0's may work just fine for ya.
  3. Jun 7, 2009 at 5:26 PM
    Seagrave
    The shock bodies are ether 2" or 2.5" but they both have the same spring right
  4. Jun 7, 2009 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm...I never checked to see if the springs are the same size....I know they are the same spring rate.
  5. Jun 7, 2009 at 5:58 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Springs are different. A 2.5" coilover requires a 3.0" inner diameter spring. The 2.0" coilover uses a 2.5" I.D. spring.
    What kind of wheeling do you do?
  6. Jun 7, 2009 at 8:50 PM
    Seagrave
    OK i guess that makes sense... that if the shock is bigger then the spring has to be bigger diameter. But I assume they have the same spring rate of #650.
    I will only be doing minor wheeling, nothing too crazy.
    Money is not really an issue here.... I just want the better of the two. Just from my little knowledge, it seems that the 2.0 would be a better choice because of the adjustability factor.
    What would you chose? Can someone put a poll on this thread to choose between the 2.0 adjustable or the 2.5 coilover.
  7. Jun 8, 2009 at 6:48 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    In your case you say minor wheeling, in my case i would go with 2.5" cause it suits my needs, but you seem like you would be happier with 2.0 but if money isnt a factor go with 2.5"
  8. Jun 8, 2009 at 6:51 AM
    mjp2
    NJ
    I have the 2.5's with the remote reservoirs because I need as much fluid as possible in the shocks to help keep them cool. I'm also not opposed to opening up the shocks and revalving the them internally to get the ride just right.
    For light wheeling, or even hardcore wheeling that isn't continuous high-speed stuff, the 2.0 shocks will be an excellent choice for their performance and easy tunability.
  9. Jun 8, 2009 at 6:56 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i run the 2.0's on mine.. unless you are going to be doing alot of high speed offroad traveling they will do just fine. i love how mine preform offroad and the onroad ride is like a caddy!!!
  10. Jun 8, 2009 at 8:10 AM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    I voted for the 2.5" Might as well have the best and never have to worry about it right. More cooler oil = longer performance with less shock fade. Run the 2.5's with some Camburg or Total Chaos upper control arms and have fun.
  11. Jun 12, 2009 at 8:35 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    From what I'm reading, the 2.5s perform better offroad. Will the 2.0s perform better onroad, or will the 2.5s beat them there as well?
  12. Jun 12, 2009 at 8:42 AM
    imsikotic
    Randy
    Temecula, Ca
    The 2.5s are better all around and well worth the money. Your on road quality will depend on how much preload (lift) you have on the springs.
  13. Jun 13, 2009 at 7:02 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    here is mine.2.0 and love them.got the lruca as well.good luck. [​IMG]
  14. Jun 13, 2009 at 9:17 PM
    Seagrave
  15. Jun 13, 2009 at 9:29 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    I believe thats a very good deal. comes with everything you need so have a bad ass suspension.
  16. Jun 18, 2009 at 8:33 PM
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
  17. Jun 18, 2009 at 9:12 PM
    Seagrave
    Off Road Warehouse is a big company in southern California. It is indeed legit. It went there yesterday and they a hard time believing the deal and had to call corporate to verify the what the website stated. It think I am going to make the purchase tomorrow.
    It came out to:
    $2179.00 (Merchandise)
    $497.00 (Labor)
    $17.00 (Misc)
    $192.15 (Wonderful California Tax)
    $2885.15 (Total)
    But I think I am going to install the lift myself with the help of my pops, then get it aligned following the install. That will save 500 bucks
  18. Jun 19, 2009 at 3:20 AM
    imsikotic
    Randy
    Temecula, Ca
    ORW is Awesome!! Definately Legit. They build some pretty sick trucks. Go for it. Do not hesitate.
  19. Jun 19, 2009 at 3:21 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    save the $500 bucks.its not a hard install at all if you have a little machanical background.i couldnt believe how easy it was when i did mine.good luck.
  20. Jun 19, 2009 at 4:36 PM
    FoxRacR17
    Kevin
    SoCal
    so i'm probably going to order from ORW today since its payday. Correct me if i'm wrong but I still need to buy a 1.5" AAl for the rear correct? I have an 09 DC that DOES NOT have the TSB done.
