Spacers + Spindles = Help!
Discussion in 'Suspension' started by Kenny650, Jul 15, 2009.
  1. Jul 15, 2009 at 7:22 PM
    Kenny650
    Kenny650 [OP] Well-Known Member
    Ok, so I have 17x9 Raceline Renegades that have 5.0 backspacing. Camburg Spindles require at least 4.5 inches of backspacing to fit the 4" spindles. If I get the Spidertrax wheel spacers, will the spindles fit? Also, will the spindles be a better ride than the Revtek I have on now?
    Kenny
  2. Jul 15, 2009 at 7:44 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    The spindles will provide a MUCH better ride than the RevTek spacers. If you wanted to go the extra mile and not spend much more, you could couple the spindles w/ a set of 5100s up front and leave them at the stock setting. This would greatly improve your ride over stock.
  3. Jul 15, 2009 at 7:45 PM
    Kenny650
    Wow good idea. I was thinking about removing the Revtek spacer and installing the stock springs but now you got me thinking twice...
  4. Jul 15, 2009 at 7:51 PM
    SC4333
    Grant
    FL
    Just removing the spacer would be a hell of an improvement. Im sure you noticed the harsh ride after it was installed.
    The stock non-TRD shocks (Aisin) are crap IMO. So an upgrade to the 5100s while you have everything pulled apart wouldn't be a bad idea. You can pick up a pair from Sonny at DSMS for about 172 bucks shipped to your door. Can't beat that.
  5. Jul 15, 2009 at 8:02 PM
    Kenny650
    I would need UCA's too right?
  6. Jul 15, 2009 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With spindles? No.
  7. Jul 15, 2009 at 8:16 PM
    Kenny650
    What about if I am going to adjust the 5100 to like 1.75 ? UCA's or no?
  8. Jul 15, 2009 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They will allow more room for alignment, but they are not required.
