King Suspenion Setup Q n A's
Discussion in 'Suspension' started by GUNZ213, Sep 21, 2009.
  1. Sep 21, 2009 at 9:38 PM
    GUNZ213
    GUNZ213 [OP] Member
    Pete
    Temecula
    Front Set-up
    So i know king oe replacement coilovers and rear shocks have the same amount of length extended and compressed. As stock billies on my trd.
    Just to confirm, once c/os are installed with a t/c uca. Only advatage i will be getting up front set to 2.5inches of lift. Is no binding form uca uniball, and alignmnet corrections? As far as travel, will it be increased? im guessing not at all. since king doesnt make extended lenght bolt in c/os. So in another words the uca is capable of allowing more travel than the king replacement c/o can provide since not be an extended length type of c/o.
    Correct me if im wrong.
    Rear Set-up
    For the rear im not lifted at all with km2 285/70/17. what is the most reasonable lift amount i should preform in the rear? without bottoming out/fully extending the shock when on/off roading. i was thinking a 1" lift if not a 1.5" max. i do haul a 6x12 ft enclosed trailer when going to go play in the dirt. and i dont have that rear leaf tsb done....:( which reminds me. im out of warranty. can i still have it preformed at the dealer at no cost to me? high hopes there huh? lol
    and input would be greatly appreciated!
  2. Sep 22, 2009 at 9:43 AM
    GUNZ213
    GUNZ213 [OP] Member
    Pete
    Temecula
    Nobody has any input on this huh...........???
  3. Sep 22, 2009 at 9:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    You expected a detailed response in under 5 minutes?
  4. Sep 22, 2009 at 11:56 AM
    GUNZ213
    GUNZ213 [OP] Member
    Pete
    Temecula
    Lol, no. Just saw people reading and no shared thoughts......
  5. Sep 22, 2009 at 4:17 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    too much reading
  6. Sep 22, 2009 at 4:18 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    yeah i got way over it when i saw all the writing
  7. Sep 22, 2009 at 4:20 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    And to get the rear TSB without the warranty was 1500$, but luckily I was still covered. Wouldn't hurt to ask though...
  8. Sep 22, 2009 at 6:34 PM
    GUNZ213
    GUNZ213 [OP] Member
    Pete
    Temecula
    thanks for the input.
    come on guys, need some feedback on this seriously!!!!!:confused:
  9. Sep 22, 2009 at 7:47 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    ok, i wont be such a dick... you are correct about the CO's and UCA's. you will gain no extra travel using an aftermarket UCA unless you have ext length CO's. you will get alignment corrections and wont have binding issues and it adds strength to your front set up. as for the rear susp IDK cause i dont have a second gen. call up king and see what they recomend for a rear lift w/ their shocks. you'll prob be fine w/ something like this if your worried about price and being able to still haul crap and not bottoming out the susp. but still call king and see what they have to say.
    http://www.iconvehicledynamics.org/catalog/product_info.php?cPath=23_41_82&products_id=106
  10. Sep 22, 2009 at 9:01 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    You will get more down travel with aftermarket uniball arms with your Kings. I asked the guy at Downsouth Motorspots about the Kings and ICON UCA"s and this was his reply.....
    Good evening,
    As far as I know the ICON Billet UCA's will clear, but I will be at
    King tomorrow and a friend of mine that used to work at ICON works at
    King now and I will ask him to be on the safe side....
    King does not make an Extended travel per say....There shock already
    has a little more droop travel then stock....Around 1.5" 1.75" of added
    droop travel....
    Let me know if you would like for me to still check on the fitment with
    the ICON UCA's???
    Thank you,
    Sonny
  11. Sep 23, 2009 at 7:03 PM
    GUNZ213
    GUNZ213 [OP] Member
    Pete
    Temecula
    cool thanks guys....
