In need of ultimate taco lift ideas!
Discussion in 'Suspension' started by 4crnryotoma, Oct 8, 2009.
  1. Oct 8, 2009 at 9:08 PM
    4crnryotoma
    4crnryotoma [OP] Member
    4corners
    01 Taco SR5 tester
    AEM Brute Force CAI, Gibson cat-back, Goodyear Dura-Trac
    I own a 2001 xtra cab 3.4l trd, i have made some breathing upgrades but am now ready for suspension. This is my daily driver including 12 hour road trips. So i was thinking 285 75 r16 with 3" lift coilover front and leaves in back, offset wheels and any other must haves. I need ideas.
  2. Oct 8, 2009 at 9:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Consider some replacment UCA's too.
  3. Oct 8, 2009 at 9:15 PM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Welcome :)
    Sounds like you got a good set-up in mind. Toytec makes great coilover kits for our trucks IMO. A lot of us are running that kit. Aftermarket UCA's would be a good idea like Chris said. Keeps you in spec for alignment and rides a lot nicer, not to mention a little more travel.
    Let me know if you need any help.
  4. Oct 8, 2009 at 9:20 PM
    4crnryotoma
    4corners
    01 Taco SR5 tester
    what about camburg does anybody run that?
  5. Oct 8, 2009 at 9:23 PM
    Ktaco
    Camburg are very good coilovers.
    Do a search on the site and I'm sure you will find ppl running them. Someone will probably chime in with names.
  6. Oct 8, 2009 at 9:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Camburg CO's are basically Re badged Sway-A-Ways. If your looking for some good CO's, consider Fox, King, Sway-A-Way or Icon. As for UCA's, If you run off road alot, Total Chaos, or Camburg are good stuff.... Light Racing seems to be getting some posative reviews too, though they use a ball joint as opposed to the uniball on the TC and Camburg arms.
  7. Oct 9, 2009 at 7:54 PM
    4crnryotoma
    4corners
    01 Taco SR5 tester
    what about leaves? was reading about the deaver 10 pack, is that overkill, is 8 plenty or is the pro comp set better. if i haul or tow will i have to get an air bag setup to stiffen the springs under load to prevent squat. also why aren't there air bump stops on daily driver rigs? seems like they would be a great upgrade for any 4x4 to soften a blow. what about lca are they only for huge amounts of travel? what do you think about co spacers for more lift? is the drop diff kit worth it? was also thinking gears, where is the best place to put them for daily driver?
  8. Oct 9, 2009 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WOW! How 'bout one question at a time? :)
    The Deaver 10 leaf is a great leaf pack. Other options are the OME/Dakar AAL. Depending on the leaf set up you go with, you may have to get some air bags for hauling. The LCA is fine for a mild lift. The Diff drop is not worth it, and new gears really depends on tire size, and how much you want to stay near the stock performance.
