-   -   Carrier Bearing Issue (http://www.tacomaworld.com/forum/suspension/56998-carrier-bearing-issue.html)
nolanspawn 10-18-2009 02:50 PM
Does something look messed up in the picture. From other pictures I could find online the rubber portion is even on both sides of the bracket but on mine it appears to be pushed out towards the rear. I cant remember if before I installed my CB drop kit if it was like this. I got curious to check the tension of the bolts after how harsh of vibrations I was feeling after the install. I cant seem to push it back in between the brackets. I cant separate the top and bottom half of the bracket because it is pressed together to make it a one piece.
http://www.nolanspawn.com/Truck/cb01.jpg
http://www.nolanspawn.com/Truck/cb02.jpg
http://www.nolanspawn.com/Truck/cb03.jpg
Here is another guy on the forums CB for reference.
http://www.tacomaworld.com/gallery/d...3-2-09_003.jpg
http://www.tacomaworld.com/gallery/d...3-2-09_002.jpg
http://www.nolanspawn.com/Truck/cb04.jpg
mpgnc64 10-18-2009 09:16 PM
I believe it should be centered in the unit, it looks like it has dropped down for what ever reason. I would mark and undo the drive shaft and see how much play is in the bushing.
