-   -   Eibach coilovers with 5100s (http://www.tacomaworld.com/forum/suspension/58222-eibach-coilovers-5100s.html)
09Doright8126 10-27-2009 10:59 AM
I've got (4) Bilstein 5100s and a set of Eibach coilovers coming my way... I can't wait to get them installed!
My question is with leaving the 5100s at stock height I should get 1.6" lift from the setup w/ the coils so if I wanted to level out the rear all I would need to get would be a 1.5" rear AAL?
Thanks in advance.
1337Taco 10-27-2009 11:06 AM
You would still have some rake because the rear is a bit higher to begin with.
geolink 10-27-2009 11:23 AM
Correct. Suggest measure now on level surface.
Also consider loads or no loads
09Doright8126 10-27-2009 12:03 PM
Will do... the rear decision will have to be made based upon exactly how much rake exists and taking in consideration my avg. normal load weights.
Thanks guys.
aww1970 10-27-2009 06:43 PM
Thanks in advance.
I am having the same installed with a 1.5" AAL. I have a topper, tow a boat, and sandbags in the bed for the winter. Without the AAL I would be pretty much level as it sits with just the topper. I still want 1.5" rake so the AAL it is.
