Question about WHEEL RUB 285/70/17
Discussion in 'Suspension' started by cgilbane, Oct 27, 2009.
  1. Oct 27, 2009 at 12:44 PM
    cgilbane
    cgilbane [OP] Well-Known Member
    Avon, CO
    07 Tacoma dbl cab
    remote reservoir fox shocks front and rear
    I put in a 3 inch FOX suspension lift front/back with 285/70/17
    I also got a body mount chop and removed the plastic in the wheel wells.
    I still get slight rubbing when almost fully turned and a little flex.
    Can I lift the body up a bit, maybe about 1 inch, ontop of the 3 inch suspension lift?
    Im wondering if this will be a safe/good way of reducing the wheel rub?
  2. Oct 27, 2009 at 12:50 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Where does it rub? Got pictures?
  3. Oct 28, 2009 at 10:47 AM
    WiTEtaco09
    WiTEtaco09 Member
    Brayden
    Utah
    09 4x4
    Tinted tails, 5% tint all around, 3" tuff country lift.
    I have the same set up and i get a little rubbing. I chopped the wheel wells too but I only get rubbing when my wheel is cranked and it doesn't even rub that much so it doesn't bother me. The body lift solution sounds doable tho. I am panning on 3 more inches of lift soon tho so i dont know that i will do anything about it now.
  4. Oct 28, 2009 at 7:23 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    You should probably post your wheel specs and what UCA's you have. There's some guys on here that'll be able to help you real quick once you give them an idea of what you're working with. And they will probably talk you out of (or try to) a spacer lift. ;)
  5. Oct 28, 2009 at 7:24 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^ ya maybe wheels are rubbing up against the uca. got the right backspacing on the rims?
  6. Oct 29, 2009 at 10:16 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    no rubbing on UCA. wheels are correct backspacing and offsett. its 4.5 and 0. no pics yet.
    no i had two guys from toyo crawlers.com who work for Toyota do the cut for me, very good very professional.
    the tires seem to be rubbing against the lowest corners of the wheel well (in front of and behind the tire)
    no pictures yet, no camera
  7. Oct 29, 2009 at 10:17 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    so can anyone tell me about if getting a body lift ONTOP of the fox suspension lift i just did is safe?
    will it really effect the smoothness of the ride quality?
  8. Oct 29, 2009 at 10:22 AM
    Rippin101
    Rippin101 Well-Known Member
    John
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    There is no reason a bodylift shouldn't be safe?! Tons of people have bodylifts and many wheel with them. Most hardcore wheelers say against them but they hold up pretty good. You aren't stacking spacers here if thats what you are talking about.
  9. Oct 29, 2009 at 1:32 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Honestly is hard to help without pics. It's like the blind leading the blind. You get no where. No camera phone, friend, or neighbor with one.
    You sure its your wheel wells and not your fender flares?
    CLICK ME That is a link to a thread i posted on where i had trimmed. Since then i have trimmed even more and had my cab mounts chopboxed. Pics of my cab mounts are in my gallery.
    Get a friend and do the curb test. Have your friend run up a curb (to give you some flex) and have him/her turn your wheel in and out while you inspect to see where exactly it is rubbing. Do that on both sides mark and cut.
  10. Oct 29, 2009 at 6:11 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    what is the wheel width? what tires are they? not all 285/70/17's are the same exact size, some have larger outer lugs that cause more rubbing.
  11. Nov 3, 2009 at 7:03 PM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    they are BFG all terrain k/o 285/70/17
