-   -   fabtech 205 aal toomuch lift? (http://www.tacomaworld.com/forum/suspension/59877-fabtech-205-aal-toomuch-lift.html)
brelandt 11-08-2009 07:27 AM
Hey guys, i bought a set of aal from amazon $53.40 shipped. They are the fabtech 205 that measure out to be 31-3/4 long. has a lot of arch.
I installed them yesterday on my 2004 reg cab prerunner with 2.7 engine. I took my measurement before I started at 36" from ground to lip of the wheel opening. after the install i drove it about 50 miles and the measurement is a little 39-1/2"!!!!
The aal kit stated 1-1/2" lift.
Where my stock leafs sagging that much? Didnt seem to be?
Has anyone else experience this.
The ride is great, better than stock and no squeaks.
pataco 11-08-2009 08:01 AM
check your shock travel as well.u might not have any.and if u do it might make brake lines REALLY tight.
brelandt 11-08-2009 08:15 AM
forgot to add that I had a set of 3.5" blocks installed years back, but removed them a year or more ago. Also had 3" lift on front which was removed as well. I also had longer brake line and shocks as well. But my ranchos maybe shot as they did not seem to extend on their own like when new.
brelandt 11-08-2009 05:53 PM
something very unexpected happened today. I applied my brakes at a traffic light when however, the truck would not slow. I paniced! I was real close to hitting the back of the car in front of me then the pedal felt as if it broke free from under my foot and went down a couple of inches and the brakes kicked in.
I never had that happen when I had my blocks installed.
Later I tried to repeat what happened and it will, but not everytime.
I adjusted my brakes by moving the bar up about an inch. The section over rear axle that adjusts how much fluid goes to the rear brakes. I havent driven yet but if I do not hit someone on my way to work in the morning than all will be good.
