taco lean in the rear...
Discussion in 'Suspension' started by HOSS454, Dec 9, 2009.
  1. Dec 9, 2009 at 1:08 AM
    HOSS454
    HOSS454 [OP] Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    so i have had the rear tsb done for some time now and noticed that my passenger sits higher than the driver side. i measured it and it came out to be almost an inch higher on the passenger side. i know there is a gas tank on the driver side but does anyone else have that problem?
  2. Dec 9, 2009 at 1:21 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  3. Dec 9, 2009 at 8:52 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    It is most definitely the rear springs. Delt with this on my 01 and now my 05. I just ordered a 1/4" shim that I plan on adding to the rear drivers side spring pack using the center pin bolt. You can have them made any size and thickness here.
    www.4crawler.com
    I'm hoping that my 1.5" AAL will make up for the other 1/4 or 1/2 inch once installed.
  4. Dec 9, 2009 at 9:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can have a local spring shop add more arch to the driver side to eliminate the lean.
  5. Dec 9, 2009 at 9:11 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
  6. Dec 10, 2009 at 8:24 AM
    atmotocrosser
    atmotocrosser Well-Known Member
    Greg
    Conroe, TX
    My local dealer didn't give me any problems when I asked for the rear spring TSB to be done on my 2010. Try a different dealer or talk with a service manager and good luck.
  7. Dec 17, 2009 at 12:11 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    this is normal
    you, the battery and the gas tank are on the left side
    watch, if your tank is almost empty, the taco lean should be less
    BTW the left leaf IS arched more to help compensate for the extra weight.
    the middle leaf is the left side 4x4/pre runner leaf
    the left one is your right one
    the one on the right is my stock 5 lug leaf....
  8. Dec 17, 2009 at 2:16 AM
    ikataco
    ikataco Well-Known Member
    06 DC Sport
    This is true.
    Checkout my photos of the TSB springs.
    Left hand/Drivers
    [​IMG]<p>
    Right Hand/ passenger
  9. Dec 17, 2009 at 10:19 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    hmmm interesting hey silverback lemme know how your fix works out i've developed a lean after installing my dakars
  10. Feb 15, 2010 at 7:48 PM
    cspiker23
    cspiker23 New Member
    Front Royal, VA
    06 Regular Cab 4x4
    I noticed this "lean" in my truck too.. but really i measured at the leaves to the ground on both sides and the springs were even on each side but for some reason the drivers side was still lower in the back.. I also noticed though that there was about a 1/4" larger gap between the cab and bed on the drivers side compared to the passenger side... I just bought a bunch of washers from the local hardware store and loosened each bed bolt on the drivers side and placed 1/4" worth of washers on the bolt at the very back of the bed then less and less further up... This cleared up my taco lean..
