Thinking of Pro Comp Stage II
Discussion in 'Suspension' started by Motoxerc0, Jan 13, 2010.
  1. Jan 13, 2010 at 2:41 PM
    Motoxerc0
    Motoxerc0 [OP] Well-Known Member
    Colin
    New Jersey
    06 4x4 DC LB Lifted
    So here is my dilemma. Right now I have a Toytec 3 inch spacer lift with an aal, stock 16" alloys with spidertrax and 33s. I knew before starting the lift it was not the best way to do it but it was all I could afford at the time. That being said, I want to fix my mistake by getting a pro comp stage II. My next problem is what to do about wheels and tires. I just put out around $700 for A/ts for my 16 inch rims about 2 months ago but understand you must run at least 17" rims or larger for the lift. My question is, if I can find someone to trade their stock 17in alloys and 33s (and maybe some cash) for my 16in alloys and 33s (I know it's a long shot) would they work with the procomp lift? I have searched but have been unable to find an answer. I have an 06 btw. Any help would be appreciated.
    Thanks,
    Colin
  2. Jan 13, 2010 at 9:53 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Im pretty sure that its not necessary to use 17 inch with the procomp because the spindle isn't any bigger then the stock one. let me check tho
  3. Jan 13, 2010 at 9:54 PM
    ktmrider
    Junk
    oooh
    my bad
  4. Jan 13, 2010 at 10:07 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    you need at least a 17 inch rim and 4.5 inch of back spacing to fit on the front the spindle that comes with the kit is beefy
  5. Jan 13, 2010 at 10:13 PM
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    yeah you need to run 17" rims... are you sure you dont want to save for LT??? if you go with the stage 2 pro comp kit, upgrade to the MX6-R remote resivor shocks...they are much better than the mx-6 shocks that come with the kit...they are only about $100 more each.[​IMG]
  6. Jan 14, 2010 at 10:24 AM
    Motoxerc0
    Colin
    New Jersey
    06 4x4 DC LB Lifted
    Alright thanks alot everyone for all your help. Next question...since i can't justify spending thousands of dollars on wheels and tires would these Cragar Soft 8's work (link provided below)and also one of those hub centric rings?
    http://www.summitracing.com/parts/CRR-3978860/
