-   -   3" lift questions (http://www.tacomaworld.com/forum/suspension/8119-3-lift-questions.html)
Dcrooks84 04-23-2008 01:55 PM
3" lift questions
Hey guys I am seriously looking at putting the toytec 3" lift on my taco. The questions I have is would it be best to put the bilstein 5100 on there as well? Along with that should I do anything else, like do the drops on the CVs? I don't want to cause excessive wear on anything because of this.
Khaos 04-23-2008 02:03 PM
Negative on the 5100s.
Which Toytec kit did you get? I'd suggest buying new shocks along with it. I'd buy the diff drop just to be safe.
Dcrooks84 04-23-2008 02:05 PM
I have not purchased a lift kit at all yet. I have no lifting experience, I was hoping to see what everyones thought was. I might go with another kit if it would be better.
ellsworth 04-23-2008 02:12 PM
lift kits
Check out truxx level kit...3" front and 1" rear...No spring disasembly...I am very pleased with this kit..I have 305/60/18's No rub, my stock tires were 265/70/16 with passenger rating..My new BFG's are the new mud terrains with a aggresive crawler style sidewall...very strong tire...the diff drop is a little over rated but I installed it anyway..there 14mm spacers for the front diff tab mounts..thats it..if you want the stock ride unchanged, check out truxx level kit...install less than 3 hrs with handtools..(if you do go with a coil preload kit or a above the mount kit, unhook the outer tie rod ends and swing em out of the way, much easier install)
zurdo41 01-03-2010 02:13 PM
BFG KM2 mud tires
Hey guys i currently have a 2006 tacoma with a 3 inch lift and i am running on 275/65r18 hancook at tires. I really dont like the way they look, am new to the offroading system so i need some help. I wanted to put some 305/65r18 BFG KM2, but i am not sure if they will fit without rubbing. Is there anything i could do to avoid rubbing on the fenders.
thanks.
pataco 01-03-2010 05:56 PM
you serious,u like that kit?
pataco 01-03-2010 05:58 PM
thanks.
dude,that is called thread jacking.glad its not my thread.:goingcrazy:
ColtsTRD 01-03-2010 06:05 PM
x2 :fenforcer:
ColtsTRD 01-03-2010 06:08 PM
Toytec makes a solid lift for Tacomas and there alot of guys on here running that same lift your inquiring about (assuming its the Ultimate Lift Kit they offer). One more thing you'll have to look into is after market UCAs to fix your alignment issues you'll have. Check out Total Chaos and Light Racing...it all depends on your budget :)
