AAL advice
Discussion in 'Suspension' started by bbaf2003, Apr 17, 2010.
  1. Apr 17, 2010 at 7:12 PM
    bbaf2003
    bbaf2003 [OP] Member
    Warner Robins, GA
    09 Prerunner TRD Double Cab
    Ok guys,
    I just finished putting on my front 5100s today. Set them at 1.75 and now even with the rear TSB I am sitting approx. 1 1/8" higher in the front than the back. was looking to be a bit more close to level so now I gotta get an AAL. My question is this. I can go with a 1.5" AAL and probably sit even. would getting the 2" make it alot of rake? I would like to tow or haul every now and then and now stare at the sky. What do you think?
  2. Apr 17, 2010 at 7:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a 2 inch aal should be fine...cause it will settle after a little bit.
  3. Apr 17, 2010 at 7:19 PM
    bbaf2003
    Warner Robins, GA
    that's what I am leaning toward. I just wanted some experienced advice. Rather do it once and be done!
  4. Apr 17, 2010 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    once and done is a good plan.:D
  5. Apr 28, 2010 at 7:32 AM
    MyMistress
    MyMistress Well-Known Member
    TN
    10 TRD Sport 4X
    Leveled front, TSB rear, TSB Transmission, Always on fog lights, Socked windshield / bedsides, Trimmed mud flaps, Weather Techs, 4 Extra d-rings, Map Light Mod, Avid Light Bar, OEM Bed Mat, Locked Back Window, Secret Stash Area,
    Is there any concern of DS vibration abnormal wear, or just awkward angle with the TSB + 2"AAL?
  6. Apr 28, 2010 at 2:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  7. Apr 28, 2010 at 2:21 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
  8. Apr 28, 2010 at 2:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no........thats just some vibrations from the angle of the drive shaft. axle wrap is where the axle actually kinda rolls forward or backward a bit and you get a clunk from it sliding near the rear diff.
    your comparison is awesome tho!!:D
  9. Apr 28, 2010 at 2:34 PM
    MyMistress
    TN
    10 TRD Sport 4X
    So.. no need for shims..? Thinking about it they work the same as shims but lower DS for straighter angle... right?
  10. Apr 28, 2010 at 2:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....and they are alot easier to install....and relatively cheap to make as well.
  11. Apr 28, 2010 at 4:50 PM
    MyMistress
    TN
    10 TRD Sport 4X
    Nice.... I saw the flat bar aluminum at HD yesterday. 1" AAL will be added soon to my TSB, THANKS FOR THE INFO!!
  12. Apr 28, 2010 at 5:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man.
  13. Apr 28, 2010 at 7:48 PM
    TexasTacoma37
    My truck still has a rake with the 5100's @ 1.75 and the TSB. Back is about 1 inch highber. Are you sure the coil seats aren't installed upside down on the billys? It's a common mistake.
