Need some input
Discussion in 'Suspension' started by 270, May 20, 2010.
  1. May 20, 2010 at 11:56 AM
    270 [OP] Well-Known Member
    Jeff
    California
    09 Dc 4x4
    Ok well i put my bilsteins on and have been trying to get an alignment done but nobody can make it ride without pulling to the left. First took it to pepboys and it pulled bad to the left. Now i just got back from another place and it still pulls. the specs from the last shop are...
    Caster left: 1.4 right: 2.0
    Camber left: .8 right: .6
    toe left: .03 right: .03
    and from Pepboys the specs are
    Caster left: 2.1 right: 2.8
    Camber left: 1.4 right .3
    Toe left: .03 right .06
    But it still wants to pull so do you guys think that the techs dont know what theyre doin, or were the shocks not properly installed on the coils. I inspected them, they seated right the plate wasnt upside down and everything seemed to look good. Is there anything that i should look for cause two alignments and it wont align? Im think about have the suspension tsb done and hopefully theyll align it and it wont be a problem. Any body got an input.
  2. May 20, 2010 at 12:00 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    What are the Bilsteins set to and have you checked your tire pressure?
  3. May 20, 2010 at 12:04 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    don't know if this will help with the pulling, but your left side caster and camber numbers should be closer to the numbers you have on the right side (caster up, camber down)
    and x2 on mjp2's post
  4. May 20, 2010 at 12:04 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    The vehicle will pull to the side with the less positive caster, and to the side with the most positive camber.
    In both cases, yours should be pulling to the left, but you actually want it to pull a tiny bit left to compensate for the road crown.
    I used to do alignments, and my guess is that during the work someone rotated your tires left to right, which is generally a no-no with radial tires.
    Try switching the front tires side to side, if it pulls the other way, then move them to the back and bring the rears straight forward.
  5. May 20, 2010 at 12:14 PM
    Jeff
    California
    09 Dc 4x4
    Yea i did switch the tires the tech said that should fix it, but no if i hold the wheel straight on most grades ill go right into the other lane.
  6. May 20, 2010 at 12:15 PM
    Jeff
    California
    09 Dc 4x4
    my bilsteins are set at 1.75 and yes i got my money back both times in case your wondering.
  7. May 20, 2010 at 12:29 PM
    AeroCooper
    NH
    Ok, that's not a pull then. What they need to do is straighten the steering wheel. They need to make sure the wheel is straight when they set the toe.
    This won't cause any trouble the way it is, other than a crooked steering wheel, which is only cosmetic, but annoying.
  8. May 20, 2010 at 12:37 PM
    Jeff
    California
    09 Dc 4x4
    Wont it abnormally wear my tires??
    So youd say its the techs dont straightening the wheel then? Cause god id hate to take off my bilsteins.
    Ohh also i read the caster should be 2.4 range and everything else set to 0, should i worry about that?
  9. May 20, 2010 at 2:10 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    anything from 2.4 to 2.8 is fine. and yes, you're correct that everything else should be zero.
    if your toe and camber are good, your tires will wear evenly, even if your steering wheel isn't straight. it just means your steering needs to be "shifted" over a degree or however far off it is via the tie rods
  10. May 20, 2010 at 2:44 PM
    Jeff
    California
    09 Dc 4x4
    ok thanks a lot fellas i comprendo now.
  11. May 20, 2010 at 3:52 PM
    AeroCooper
    NH
    Yeah, what he said.
