-   -   How to remove front springs (http://www.tacomaworld.com/forum/suspension/95917-how-remove-front-springs.html)
IDtrucks 06-02-2010 06:00 PM
I want to lower the front of my truck 1" and the back 2". The back is easy...blocks. And for the front im buying another set of stock springs and cutting a coil to get my 1". Im not quite sure how to remove the front springs. Im going to a friend's house who has just about every tool imaginable but i need a tips on removal. I searched for a topic but couldnt find any. If anyone has a good write up or some pics any help would be great. Thanks!:D
EL TACOROJO 06-02-2010 06:04 PM
spring compressor from auto zone. but why cut the coils just as bad as heating them up and usein the weight of the truck to collapse them
IDtrucks 06-02-2010 06:38 PM
thats it? what about taking apart...everything else. Because for 1" i dont want to but a $100 set of springs. Also for 1" one coil isnt that bad.
LostRebel 06-02-2010 06:43 PM
How are you going to lower the rear with blocks? I'm curious to know as I haven't heard of this.
IDtrucks 06-02-2010 07:39 PM
:confused::confused:wat?really?U prolly have heard of it, it just didnt click in my post. Its the most common way to lower a truck. You put a block (1-4") in between the back axle and the leaf springs. and tighten it down with longer u bolts. Thus increasing the space between the leaf springs and axle. Bringing the bed closer to the wheel and making it lower
http://www.michaelrenz.com/typhoon/m...ringBlocks.JPG
LostRebel 06-02-2010 07:54 PM
Gotcha! :thumbsup: I wasn't visualizing underslung springs. Perfectly clear now.
Kelson 06-03-2010 01:59 AM
u don't want to go any lower? cause cut springs won't really ride that great. you can get an easy 3" of drop out front with the ball joint flip for around $50.
you have a first gen truck right? just making sure. cause im not super familiar with working on them...
