Timbren Bump Stops reviews???
Discussion in 'Suspension' started by Eesh, Jun 7, 2010.
  1. Jun 7, 2010 at 8:12 PM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    For those of you that have them... I'm just looking for personal opinions or reviews on Timbren Bump Stops.
    Trucknorris likes this.
  2. Jun 7, 2010 at 8:20 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i used to have them, i thought they were pretty nice but not amazing.
    worth the money? for me, no. they had to much rebound and made landings too bouncy
    but they did cushion great and made impacts soft
    ChadsPride likes this.
  3. Jun 8, 2010 at 2:44 PM
    Eesh
    trd Sport
    bump
  4. Jun 8, 2010 at 2:51 PM
    wolfeye
    wolfeye Well-Known Member
    If you tow you may want to consider getting a set for the rear end. If I were you I'd rather just invest in a good set of coilovers, new leaf pack, and rear shocks.
  5. Jun 10, 2010 at 7:19 PM
    StandupTaco
    StandupTaco Well-Known Member
    2010 DC TRD Sport
    If you're talking about the Timbrens SES system, I no likey! Too rough hitting on the Taco when going over bumps on a well used road, paved. As others have said, invest in something else unless you tow a lot of weight! IMHO...
  6. Jun 11, 2010 at 7:38 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    check out wheelers they have some super bumps for cheap.
    YotaDan likes this.
  7. Jun 11, 2010 at 9:44 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I have them on the rear. The trailer I tow has a lot of tongue weight and with my 5100's up front it looked retarted evertime the back end would squat. I didn't want to get pulled over because it looked like my trailer was to heavy. I installed the timbrens inn just the rear (with my aal 4" lift). my leafs are old but now when I have the trailer on the truck sits level. Looks much better. I am horrible at noticing ride quality so I couldn't help you there. I have tires set at 80psi so it is already a bumpy ride.
    If you do a lot of heavy hauling or towing these are a good buy. they will help save your leaf springs.
  8. Jun 11, 2010 at 9:54 AM
    jandrews
    '09 FourDubDee TRD OR
    If you're hitting the bumpstops unladen on a paved road, something is very wrong with your rear suspension.
  9. Jun 11, 2010 at 10:16 AM
    Vidman
    Vidman Protected by Glock
    Rick
    central Mass
    black TRD sport AC
    Not Enough
    I have them but i also have alcan custom leaf paks I have them set at around 3 inchs of clearance. they are perfect for weights that i haul. empty you never even know you have them.
  10. Jun 11, 2010 at 2:16 PM
    StandupTaco
    2010 DC TRD Sport
    I'm not hitting the bump stops, I'm was occasionally hitting the Timbrens and she hit's hard even with the 1- 1 1/2" space/gap. I have the 4 leaf pack and it rides nice now without the Timbrens installed, just factory Bumpstops. The Truck is new like 2 months new so I can't see the leafs being bad.
  11. Jun 11, 2010 at 2:26 PM
    jandrews
    Timbrens are bumpstops.
    I repeat: If you're hitting the bumpstops without a load in the bed on paved road, something is wrong with your truck. I don't care how many leaves (I have the TSB springs as well), how much clearance, how new, etc. - that should never happen, ever.
  12. Jun 11, 2010 at 2:36 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I have them and I really don"t see how that's possible, you must have done something wrong. To the OP here is a more accurate review of the Timbrens : http://www.toyotanation.com/forum/showthread.php?t=258979
  13. Feb 1, 2017 at 5:25 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Anybody running Timbren bumps up front?
    Looking for feedback, thank you all.
    Firebird likes this.
  14. Feb 1, 2017 at 2:08 PM
    ChadsPride
    Thanks for the reply! :fistbump:
  15. Feb 1, 2017 at 2:15 PM
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Thread necro AF
  16. Feb 1, 2017 at 2:16 PM
    ChadsPride
    :D:D:D
    Looking for ACTUAL reviews!!!​
    Firebird[QUOTED] likes this.
  17. Feb 1, 2017 at 3:00 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    He meant you brought back a dead thread.
    I say good job searching for what you want to know. If you started a new thread someone (maybe me) would chime in and say try a search, LOL.
    Firebird and ChadsPride like this.
  18. Feb 1, 2017 at 4:01 PM
    ChadsPride
    Haha!! I'm just glad I got a reply!
    :fistbump:
    ballataco and Firebird like this.
  19. Feb 2, 2017 at 11:04 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    They work great for the right application. Daily driver that sometimes sees a full load of gravel, lumber, firewood, etc. When heavily loaded they help to minimize excessive sag as well as stabilize the vehicle while going around corners while still allowing the suspension to work up and down over bumps and dips.
    fla_sun and ChadsPride like this.
  20. Aug 1, 2019 at 12:32 PM
    JustEd
    JustEd Well-Known Member
    Ed
    California
    2013 TDR Sport 4x4
    aFe air filter, TDR exhaust, Nitro 4.56, TRD Beadlock, KO2 285/75R16, KING's
