Body Lifts?
Discussion in 'Suspension' started by mnudo200827, Jun 8, 2010.
  1. Jun 8, 2010 at 5:36 PM
    mnudo200827
    mnudo200827 [OP] Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    Just wondering if anybody knew of any body lifts for the 2005+ tacomas that are 1-2", all i have seen is 3" body lifts. Thanks...Mike
  2. Jun 8, 2010 at 6:11 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Everyone on here is going to tell you not to put a body lift on. But its your choice and performance accesories has a 1 and 2 inch I believe.
  3. Jun 8, 2010 at 7:28 PM
    mnudo200827
    Michael
    Corona, CA
    I know everybody is going to say that, but thats why i only want a max of 2", really 1.5" would be ideal. I am going to put on the camburg spindles and icon coilovers in the front and put those between 2.5"-3" and put a custom leaf pack for the rear that has lift in it. Going to be putting on 35" tires, and was going to put a small body lift if needed, and i figured 1-2" would be good enough. But i will check out performance accesories. Thanks...Mike
  4. Jun 8, 2010 at 7:30 PM
    mnudo200827
    Michael
    Corona, CA
    I am going to be putting in icon coilovers instead. But thanks for the input.
  5. Jun 8, 2010 at 9:43 PM
    mnudo200827
    Michael
    Corona, CA
    Ya i saw that thread a little earlier in the day, i was thinking of getting the icons with the piggy back resevoir, but if the price is really $500, it is a deal that i cant pass up. Do you know what spring rate come on these, i thought i saw that icons came with 650#. Thanks for the heads up....Mike
  6. Jun 8, 2010 at 9:59 PM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
    :facepalm::smack::crapstorm:NO BODY LIFT
  7. Jun 9, 2010 at 1:49 AM
    mnudo200827
    Michael
    Corona, CA
    calm down guys, only going to get one if neccessary.:eek:
  8. Jun 9, 2010 at 3:32 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Yeah, posting a thread asking about body lifts here is pretty much not going to get you many suggestions.
    If you can't find the right size kit, you can always buy the 3" and cut down the pieces to whatever size you want. You can also make your own.
    Or you can just screw the body lift altogether and do a suspension lift like a smart person would.
  9. Jun 9, 2010 at 6:32 AM
    mnudo200827
    Michael
    Corona, CA
    I amalready doing a suspension lift, but was going to add a samll body lift if neccesary to fit the big tires.
  10. Jun 9, 2010 at 9:37 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    just cut and trim. gut your wheel wells. no body lift lol.
  11. Jun 9, 2010 at 10:34 AM
    sachou
    Sam
  12. Jun 9, 2010 at 10:57 AM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
  13. Jun 9, 2010 at 1:31 PM
    mnudo200827
    Michael
    Corona, CA
    well then does anybody know of another way to gain lift after the camburg spindle lift and coilover lift?
  14. Jun 9, 2010 at 2:30 PM
    tacomakid96
    Phil
    Out n' about
    Not anything other than a drop bracket. If you want more lift after your coil overs you would have to get a body lift to achieve more lift.
