#81 |
![]() Watching Ed Live vicariously through mjp2
The Oil pan on the 2.7 is longer than the V6.
#82 |
Born in the Backwoods
Those Fumoto plugs...Can you find them locally? Advance Auto? Auto Zone? Or are they online only...
__________________
Lets Go Mountaineers... |
#83 | |
2009 BCS Champs
Here's where I bought mine. Don't get the F-103N... it hangs down way too far (for my comfort). I didn't think it'd hang down that far and I got it. I had to grind the nipple off to make my own F-103. Edit: Also, DON'T get the little metal safety clip. It looks like it's pliable and can easily be used to fit over the valve and keep it from unlocking, but it's completely worthless. I threw mine away. It would take a LOT to open that valve by accident. No little pebble or rock is going to do it. You'll see what I mean when you get one.
__________________
. I am mws4ua, and I approved this message.- I'm selling some Tube Steps and some rear Floor Mats
#84 | |
That's just like your opinion, man
__________________
The Older I Get, The Faster I Was ![]() The quickest way of ending a war is to lose it. - George Orwell BakFlip Bed Cover Shorty Antenna Peripheral iPod Interface Garmin Nuvi RAM Dash Mount Add'l OEM Bed Tie Down Rings Westin Access Cab Nerf Bars (I think access cab bars look better on the Double Cab) Pop N' Lock Tailgate Lock Ideal Turn-Key Clamp (to secure tailgate) Spare Tire Security Cable Fumoto Oil Drain Valve WheelMaster Stainless Spare Air Hose Extender Redline Elite Hood Struts ProTecta Bed Mat |
#85 | |
2009 BCS Champs
Kidding, of course. I'm actually glad I got the 103N... I was able to put it on and see for myself that I wasn't comfortable w/ how far down it stuck... I'm also glad I had access to a grinder.
__________________
#86 |
Don't over tighten the drain plug. I don't know what the torque spec is but it's probably pretty low. And whoever is using teflon tape, quit, never done that..
I like that plastic bag around the filter idea on the 4 banger when you unscrew it. No more leaked all over my arm messes! |
#87 |
Drian plug torque is 30 ft.-lbs.
#88 |
so i just changed my oil this afternoon. I dropped the oil drain plug some place in the engine bay, so its probably lost forever. I just cut out a piece of the plastic tubing that i got from home depot, covered one end and used that as my plug.
My question is, will the heat from the engine bay cause that rubber tubing to melt onto the plug? It seems like it gets really warm in that area, but since the plug isnt directly connected tothe motor, it doesnt seem that it will melt the rubber part to the drain plug. So do you guys think i'll be alright with my homemade drain plug or should i take it off.
__________________
![]() 1999 Honda Prelude Type SH - SOLD 2009 Toyota Tacoma DBL Cab 4x4 with SR5, JBL system and tow package -OEM roof rack, OEM bed mat, All weather floor mats, Toytecs 3inch Ultimate Lift Kit, Total Chaos UC |
#89 | |
#90 | |
thanks for the quick reply. Only hard part for changing oil on this truck was getting that plug off behind the filter. but overall soooooooooo much better then my Honda prelude. Filter location on that was right behind the engine, so youd have to stick your arm into the engine compartment where it gets all cut up
__________________
#91 |
I saw this question asked earlier but never answered. Does it matter if you use the Mobil 1 short (standard height) filter over the taller one?
#92 |
I use the Mobil 1 Extended Performance...I think it is M-102.
__________________
#93 |
CenTex Honky
I changed my oil today for this first time on this truck.
I bought an EZ Change drain plug from O'Rileys ![]() ![]() I was worried about the mess from the oil filter so I opened the filler cap and pulled the dip stick first then I drained the oil. Once it was drained I pulled the filter. No mess at all. The filter was completely drained. Here is a pic of the resivoir when I pulled the filter ![]() And the filter its self ![]() When I was putting the drain hose on I found out somewhere along the line the cap was never replaced so I made my own. I cut a length of hose and I had an extra clip from pulling my mud flaps and it fit perfect. ![]() ![]() I also made it long enough that it will be easy to pull on the next change.
__________________
#94 |
Do I need...
Mornin'! I was plannin on doing my first oil change on my own at 3000 miles on my truck. Do I need to get the new oil cap?
#95 |
I meant a new oil plug gasket?
#96 |
SNOW!!
It wouldnt do much harm if you re use it once or twice. But i would get one, sometimes if the dealer is nice they will give you one for free. if not, they charge like 85 cents ha
#97 |
Thanks! I appreciate it.
#98 | |
The dealership apologized, gave me a new oil filler cap, and called it good. I found the filler cap the next time I pulled the bottom shroud when the original one fell out. --->Rob |
#99 | |
__________________
#100 |
never go to jiffy lube very bad reputacion.
| Thread Tools | Search this Thread |
| Display Modes | |
| Oil Filter mess? on First oil change. | mvega1969 | 2nd Gen. Tacomas | 16 | 02-13-2010 03:24 AM |
| 1st oil change and oil filter? | clayj | Technical Chat | 23 | 04-04-2009 07:20 AM |
| Oil Change | MooseTX82 | Technical Chat | 12 | 08-25-2008 12:05 PM |
| oil change | steelerfan7p | 2nd Gen. Tacomas | 26 | 07-31-2008 05:09 PM |
