#161 |
Slap Chop
lmao!
#162 | |
I'm thinking you had no mess because the filter had no anti-drain valve. Better filters use these so oil is ready to flow immediately when the truck is started. I noticed when changing oil on my old 88' Runner for the first time, the previous owner used the cheapest filters possible, and they would be empty when I went to spin them off. After switching to a better filter with the valve, the filter would always be full when removed. |
#163 |
eatin' bass turds
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Eric
I wonder how well that EZ Drain works and what it cost. I spent $25 on a Fumoto and look forward to my next change to try it out. It has the nipple on it so I can connect a hose and run it right into an empty container.
I also plan to run a hose from my oil filter resivoir to another bottle. Nice and clean! Though it would be nice if the filter was empty when I pulled it off and I will try the dipstick trick. We'll see...
__________________
![]() Lets go Steelers Lets go Pens |
#164 |
Suggestions!
I have a 96, 4X4, 3.7. I want to do the following: Replace the clutch fan with an electric - I plan not to run this off the thermostat but will be on while running. Add a dual-cooler radiator for tansmission and oil - mounted on my push-guard with it's own fan (I'm designing a box to hold it). I want to also re-route the oil filter and place this new filter in the same area as the dual-cooler. My question is: Is there a concern regarding transmission preasure and oil preasure by adding length to the flow of oils when I place them in front of the radiator? |
#165 | |
Slap Chop
#166 |
AKA Pimp Master Flex
About to do my first oil change at 2,500 miles but have a couple questions
1- Are any oil filters better than others? What's a good filter? 2- My Maintenance Reqd Light hasn't come on yet, will the reset procdures reset the mileage count so that the light doesn't come on for another 4,500/5,000 miles? |
#167 |
3.4L.....I had a type-o (3.7), but it's a 3.4L.
#168 |
Slap Chop
Maybe you should start a new thread about the issue. You may get more views.
#169 | |
Omnipotent
2. Yes, the reset procedures will reset the light to come on 4500/5000 from the mileage you reset it last at. |
#170 | |
knows a spot right over the hill
If you want to spend a bit more, go with a Mobil1 filter. Right now theres a Mobil filter on my truck, but whenever I change my oil sometime next week I'll be using a Napa Gold.
__________________
#171 |
#172 | |
Slap Chop
Push and hold the ODO reset/select button insert key and turn key to "ON" but dont start the trcuk (Keeping the button pushed) You will see -------- In the ODO display, and the dashes will disapear one by one, until the ODO blinks "00000", then let go of the button, and the system is reset. Do this after every oil change.
#173 |
You feelin' lucky, punk?
^^ Great info.
__________________
![]() "Come to me, all who are weary and burdened, and I will give you rest." Matthew 11:28 |
#174 | |
Thanks for the info!
#175 |
Slap Chop
#176 |
eatin' bass turds
Just did my first oil change and it wasn't as clean as I had hoped. It was far better than other trucks I've owned but I still have to adapt some things.
Actually, it was messy because I use a standard oil pan and the oil came out so fast it splashed all over the place (I did it when the oil was hot). Then I couldn't get the filter off that the dealer put on. Well, it was also still hot and hard to touch. Finally, I didn't have the right size hose to connect to the filter drain pan. SOOOOO....... I installed my Fumoto drain plug with the hose attachment. Next oil change, I'll drain right into an empty bottle (laundry detergent bottle). I also need to get the right size hose to fit the filter housing. No mess and easy peezy! QUESTION: Does anyone leave a rubber hose attached to the filter drain pan drain plug? It gets hot and I would be worried about it melting the hose.
__________________
#177 |
Good information, Anyone have a list of filters that will can be used on the Tacoma? Not just the name brand, but their numbers as well, Thanks. D
#178 |
Still ignoring the damn swine flu
For those of you that do not have one, you need to get one of these:
![]() These things are worth their weight in gold. You open two plugs, and the oil drains out of whatever you're draining and flows inside the container. Then you just plug it up and throw it back on the shelf in the garage. When it gets full, just take it down to your local auto parts store and dump it in their recycle tank. Much better than saving empty containers, etc. Speeds the process as well.
__________________
#179 | |
![]() You end up going to BeaveRun this weekend at all?
__________________
#180 | |
ROLL TIDE ROLL
I empty it into a 5-gallon paint bucket I keep at the house after each use. It's still a great purchase, though. |
| Thread Tools | Search this Thread |
| Display Modes | |
| 1st oil change and oil filter? | clayj | Technical Chat | 23 | 04-04-2009 08:20 AM |
| Oil Change | MooseTX82 | Technical Chat | 12 | 08-25-2008 01:05 PM |
| oil change | steelerfan7p | 2nd Gen. Tacomas | 26 | 07-31-2008 06:09 PM |
| Oil Filter mess? on First oil change. | mvega1969 | 2nd Gen. Tacomas | 8 | 02-22-2008 02:01 PM |
