Clutch Replacement(Needed!) difficult level?
Old 10-20-2010, 06:20 PM   #21
stinky_truck will become famous soon enough
stinky_truck's Tacoma Gallery
there was 11 bolts around the bell house to remove.
Old 10-20-2010, 06:23 PM   #22
torqued flywheel down evenly @ 83 newton meters. used alignment tool (17mm husky w/ext.)
Old 10-20-2010, 06:24 PM   #23
this brass looking side i put towards the flywheel side.
Old 10-20-2010, 06:26 PM   #24
aligned clutch disk (notice clutch disk side is different than flywheel side)
Old 10-20-2010, 06:27 PM   #25
torqued pressure plate on evenly.
Old 10-20-2010, 06:29 PM   #26
removed stock throwout bearing. tapped sleeve on w/flat head chizzel. tighten w/allan wrench.
Old 10-20-2010, 06:30 PM   #27
put new throw out bearing provided by urd.
Old 10-20-2010, 06:33 PM   #28
had a buddy help me align transmission greased the trans. bolts tighten bell housing evenly. the two longest bolts(w/14mm head) enter behind the starter. bleed slave cylinder until clutch pedals is good. this urd stg III clutch combo kit works amazing! the clutch grasp quick!
Old 11-18-2010, 10:41 AM   #29
4x4Tacoma is on a distinguished road
4x4Tacoma's Avatar
4x4Tacoma's Tacoma Gallery
how long did the whole job take?" and did you fully remove the tranny or jst drop it down with drive lines still intact? or did you have to remove all the drive lines? did you have to support the engine as discussed earlier thanks ben
Old 11-18-2010, 11:09 AM   #30
i did not support the engine, bcuz of the engine mounts. i did remove front and rear drive shafts. this job was about a day & a half while working full time. let me know if u got more????
Old 11-18-2010, 08:58 PM   #31
Chris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shedChris(NJ) is one of the sharper tools in the shed
Chris(NJ)'s Avatar
Law Enforcement:
Chris(NJ)'s Tacoma Gallery
Decided against the sleeve kit to prevent TOB issue? I'm surprised....figured while you're doing this, you could've thrown on that kit.
Old 11-19-2010, 02:08 PM   #32
4x4Tacoma's Avatar
Well since my question I had decided just to let fucktoyota do it since I wasn't sure how much time and after pricing the stage three alone and almost ordering the kit without throw out bearing I got discouraged cause I felt URD was being shady on what they send in the kit so .... Forked out 1200$ for toyfuckin yota to fix it I'm so pissed I shouldn't have bought my pos toy. I'm planning on selling it any takers it's got a new clutch package and resurfaced flywheel and only 50k miles POS jap
Old 11-19-2010, 02:09 PM   #33
4x4Tacoma's Avatar
Oh and come to find out it is was the pressure plate assembly that broke and Toyota wouldn't pay for it
Old 11-20-2010, 12:23 PM   #34
i got the URD throwout bearing kit for like $250.something and the stg III clutch combo kit(new pressure plate, clutch disk, and flywheel) for like $700. something which all together came out to almost a $G. than i invested in big jack stands(4) and a floor jack and a transmission jack plus i have jus enough space in my garage to do the job. all the work is for one man, except aligning the transmission u would of needed another person. it was all worth it for me. F toyota stock clutch parts to expen$ive. URD parts = high quality (totally worth it).
Old 11-20-2010, 12:25 PM   #35
i through on the urd throw out bearing that came with a sleeve, while replacing clutch.
Old 11-20-2010, 01:24 PM   #36
4x4Tacoma's Avatar
Yea I just got my clutch and truck back and I will post some pics the wouldn't cover my clutch which under the 5yr 60k mile warranty should be covered unless they feel its ware and tare item or from abuse and it I believe was neither. The enire clutch pad was sheared off from the center peice of the clutch pad and they said it's a abuse item which I wasn't racing nor off road at the time. I will post pics please stand by
Old 11-20-2010, 02:09 PM   #37
4x4Tacoma's Avatar
[/IMG]my old clutch pad as u can see very poorly made and can not handle the torque in which the engine has provided be carefull if ever need to paas a car as i was doing an i down shifted and this happened and as for now the dealership wont pay for it or warranty but i have opened a claim and will keep you all up to date
Old 11-20-2010, 02:12 PM   #38
4x4Tacoma's Avatar
Old 11-20-2010, 02:13 PM   #39
4x4Tacoma's Avatar
Old 11-20-2010, 02:14 PM   #40
4x4Tacoma's Avatar
Clutch replacement BrianPK 1st Gen. Tacomas 21 05-07-2014 02:13 PM
Manual Clutch Difficult Engaging TSB (T-SB-0385-09) BSP4x4 2nd Gen. Tacomas 24 12-13-2010 08:32 AM
replacement clutch? commtrd Technical Chat 2 09-05-2009 07:41 PM
whats needed to level off the front of my o8 tahoermk 2nd Gen. Tacomas 7 11-03-2008 12:21 AM
New Clutch Needed S-Runner '01 Technical Chat 0 07-29-2008 02:37 AM
