2000 Tacoma Emergency Brake Light Problem, How can i fix it? PLEASE HELP
Old 10-07-2010, 09:56 PM   #1
Rolling Low And Smashing Hard
frankygomez01 is on a distinguished road
frankygomez01's Tacoma Gallery
So my Emergency Brake light keeps turning on while im driving and i cant figure out why. I changed the Brake switch but i still have the same problem and my brake fluid is fin as well. Any suggestions?
Old 10-07-2010, 10:03 PM   #2
joes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shed
joes06tacoma's Tacoma Gallery
Did you change the switch on the parking brake? Or on the brake pedal? The two things that will turn the light on are the parking brake switch and the low brake fluid switch. Perhaps the float switch in the brake fluid reservoir is bad?
Old 10-07-2010, 10:07 PM   #3
i changed the one on the parking break pedal and it didnt go out so idk what to do
Old 10-07-2010, 10:24 PM   #4
If it were me, I would look under the dash at the parking break switch and make sure it's actually getting pressed in. Then, pop the hood, disconnect the connector going to the brake fluid reservoir switch and see if the light goes out with the park break off. If not, try jumping the two terminals inside the harness connector at the reservoir switch. I am not sure if you are opening or closing the circuit when the brake fluid gets low.
I am thinking you have a sticky float switch.
Old 10-07-2010, 10:34 PM   #5
Lest We Forget
cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack
cmack's Tacoma Gallery
Lube up the release spring underneath your truck. Fixed my issue...can't hurt to maybe give it a shot for yours?
Look underneath your truck driver's side. Bout the middle of the cab, I'd say?
Old 10-07-2010, 11:33 PM   #6
I fixed it right now, guess my dad didnt check my break fluid good and turned out it wasnt topped off, now that i topped it off it turned the light off.
thanks anyways guys for the help
Emergency brake fix cmack 1st Gen. Tacomas 41 10-05-2014 10:13 AM
Emergency brake light BKar 1st Gen. Tacomas 2 04-14-2010 01:09 AM
Emergency Brake Problem toyhunta Technical Chat 4 10-18-2009 03:38 AM
emergency brake light comes on 4421.frank 1st Gen. Tacomas 13 03-14-2009 10:10 PM
Emergency brake light? TacoMike Technical Chat 4 05-23-2008 11:06 AM
