Sway Bar Connected Vs. Disconnected With an Interesting Observation
Old 10-18-2010, 05:11 PM   #1
Prepared for Bambi
Jason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shedJason'sLawnCare is one of the sharper tools in the shed
Jason'sLawnCare's Avatar
Jason'sLawnCare's Tacoma Gallery
Letís get the bs out of the way. I do not recommend you disconnect your sway bar or completely remove it. There are obvious safety concerns involved with it. More significant, This thread is not a debate and if it becomes one it will be locked immediately. The reason I post this is to share my observations of an experiment I ran.
I was curious what the benefits of a disconnected sway bar over a connected sway bar are. I also wanted to make sure that disconnecting the sway bar couldnít cause mechanical damage(make contact with the suspension etc.).
My experiment consisted of using the hilift to get one side of the truck completely off the ground. My goal was to get the front tire approximately 1Ē off the ground. First I did this with the sway bar connected and then with it disconnected.
Enough with the Chit Chat, here are my observations
Sway bar connected-No jack present
Sway bar connected-Jack lifted passenger front about an Inch off the ground
Sway bar disconnected-Jack lifted passenger front about an Inch off the ground
Now the juicy part-I went over to the driver side slider to see if any problems arose with the sway bar disconnected
Sway bar disconnected-Jack on drivers side-lift about 2 inches
Then I go over and check before I continue and discover this
Sway bar disconnected on passenger side-Jack on Drivers side-lift about 2 inches
I didnít think that looked right, so I went over to the jack and pushed it down one more time
Sway bar disconnected on passenger side-Jack on drivers side-lift about 3 inches
On the farther away pics it's easier if you click on it and get a full size image.
To conclude, The disconnecting the sway bar has obvious gains in travel from wheel to wheel but it canít be done. The sway bar simply gets pushed right into the cv. If I continued to lift the drivers side it would have just gone down farther and farther into the cv. Now add this to a spinning shaft and your guaranteed a shredded boot and thereís a good chance youíll destroy the cv entirely considering the force the sway bar can push down.
*Reminder This thread is not a debate and if it becomes one it will be locked immediately.
Old 10-18-2010, 05:17 PM   #2
Carolina Alliance Southwest Region Ambassador
jandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shedjandrews is one of the sharper tools in the shed
jandrews's Avatar
jandrews's Tacoma Gallery
So...in other words *remove* it?
Old 10-18-2010, 05:18 PM   #3
Prepared for Bambi
If you don't want to have a sway bar then the only option is to completely remove it. It's either all on or all off. This is also answers the question as to why nobody makes sway bar disconnects for 2nd gen Tacos.
Old 10-18-2010, 05:21 PM   #4
jandrews's Avatar
Right. I mean, I generally wouldn't EVER recommend disconnecting a part and then leave it flopping around on the vehicle.
We needed an experiment to figure this out?
Old 10-18-2010, 05:21 PM   #5
BIG DADDY
brutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shedbrutalguyracing is one of the sharper tools in the shed
brutalguyracing's Avatar
brutalguyracing's Tacoma Gallery
i thought when u disconected the sway bay you were supposed to remove it?
Old 10-18-2010, 05:26 PM   #6
DaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shedDaWillDaBeast is one of the sharper tools in the shed
DaWillDaBeast's Avatar
DaWillDaBeast's Tacoma Gallery
Good research, its to bad somone cant make a quick disconect for us. I guess I'll just keep mine on in preping for the kamikaze deer to run out infront of me.
Old 10-18-2010, 05:26 PM   #7
Prepared for Bambi
"We" didn't need an experiment at all. I did an experiment because I was curious the what the difference would be side by side and I figured I would share my observations with TW.
I guess it wasn't such common knowledge for me. I always hear about people wondering why nobody made a quick disconnect for the Taco.
Old 10-18-2010, 05:27 PM   #8
The Welfare Cadilac
Max-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shedMax-4_Yota is one of the sharper tools in the shed
Max-4_Yota's Avatar
Max-4_Yota's Tacoma Gallery
Great write up, even though I don't have a 2nd gen.
Old 10-18-2010, 05:27 PM   #9
BIG DADDY
i never understood how the sway bay disconects worked anyhow
live n learn
so are you keeping it????
Old 10-18-2010, 05:27 PM   #10
Prepared for Bambi
I think that's the reason why a quick disconnect wasn't developed. The only way to disconnect it is to remove it as brutalracingguy and Jandrews have made clear.
Old 10-18-2010, 05:29 PM   #11
JDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shed
JDMcQ's Avatar
JDMcQ's Tacoma Gallery
You are wrong!
Old 10-18-2010, 05:30 PM   #12
chris4x4's Avatar
chris4x4's Tacoma Gallery
live n learn
A Sway bar disconnect actually removes one side of the sway bar, allowing it to act as if disconnected.
Old 10-18-2010, 05:30 PM   #13
Prepared for Bambi
Thank you. I'm not sure how the sway bars are setup on the first gens, but I can tell you that if you disconnect it that it will go up and down a significant distance and contact anything in it's path.
live n learn
I always thought that it would disconnect on the spindle. I'm going to look into how other models work.
Yes I'm keeping it. At least until I get firmer suspension because right now it rocks like a sailboat with the extra weight over the front.
Old 10-18-2010, 05:34 PM   #15
BIG DADDY
are you saying you want to remove some of the extra weight up front
id be very willing to meet you to remove that bumper...my winch needs a home
Old 10-18-2010, 05:34 PM   #16
chris4x4's Avatar
Here is a Disco'ed sway bar
Old 10-18-2010, 05:38 PM   #18
BIG DADDY
do you have any further pics looks like a sweet system...
does it pin in then like lock up??
Old 10-18-2010, 05:38 PM   #19
Prepared for Bambi
LOL! NO WAY! I've got some ome components in the mail now
Thank for posting that. So they completly removed any part that could cause harm.
Upon a google search I discovered that the 4 runners(3rd gen I believe) had the sway bar connected to the lca out of the way of everything
http://www.toyota-4runner.org/3rd-ge...isconnect.html
Sway Bar chadderkdawg Suspension 32 01-30-2012 02:47 PM
Anyone have pics of before and after with sway bar disconnected? TRDBandit 2nd Gen. Tacomas 3 04-19-2011 09:27 PM
FS - Toytec Sway Bar Relocate Kit, Sway Bar End Links & Bushings Sublime Buy / Sell / Trade 16 02-17-2011 10:59 AM
Interesting observation on local gas station rbeezy General Automotive 23 12-01-2010 05:19 PM
WTT Tacoma TRD Sport Sway Bar for a TRD Offroad sway bar... sincitytaco Buy / Sell / Trade 3 08-09-2009 12:30 PM
