how to mount roll bar?
Discussion in 'Technical Chat' started by MMazz365, Oct 31, 2010.
  1. Oct 31, 2010 at 7:58 PM
    MMazz365
    MMazz365 [OP] Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    Im looking to build a roll bar and put PIAAs on top but my question is how to mount it to my side rails on my bed?
  2. Nov 1, 2010 at 10:37 AM
    MMazz365
    Michael
    NY
    TRD Off Road
    i plan on mounting on the side rails, but how? im going to put a plate on the bottom of the bar to mount it but how could i get a bolt in the inside and just drill right through ?
  3. Nov 1, 2010 at 1:32 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Your best option would be to cut out squares in your bed and mount the bar directly to your frame, welding if possible. If you mount it to your bed rails, the bolts will eventually pull out, unless you literally just leave your truck parked and never touch it, ever. Like what Wolfpack was saying.
  4. Nov 1, 2010 at 1:32 PM
    mjp2
    Milton Juevo Portimous II
    NJ
  5. Nov 1, 2010 at 2:07 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
  6. Nov 1, 2010 at 2:10 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    What about a plate and attach it to the bed bolts at the cab.
  7. Nov 1, 2010 at 2:18 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    That could work. The D rings were just much easier to remove. and since the front wasnt attached to the frame there wasnt any point in attaching the rear to the frame. Wont help in a roll over but I like the look and really lights up the road at night.:D
  8. Nov 1, 2010 at 2:22 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea arent the d-rings just to the bed? The bed bolts are to the frame. That's where I would put it.
  9. Nov 1, 2010 at 2:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Lessons from the pro?
  10. Nov 1, 2010 at 2:44 PM
    DionysiosA76
    DionysiosA76 Captain Analyzer
    Dionysios
    Barrington, IL
    07 Taco Sport DC 6 spd-SOLD FOR CUMMINS
    Totally custom straight pipe exhaust sourced from an 01 Cummins (fabbed up by yours truly), ScanGaugeII, Westin Bull Bars, air horns, Truxedo tunneau, Black decals, Black rotors, black calipers, Secondary Air filter removal, reengineered dirtbike hauler, auxillary back up lights, blacked out tail lights, socked by Sockmonkey, blacked out hi-stop, TRD stickers (+300hp :) Owens Running Boards, Greek flag shifter, Garmin Nuvi 755w GPS, Cobra 25ltd CB with a 4' fiberglass whip... and never paid anyone nuttin to do it.
    i'm doing the same thing soon, glad to see that it looks good
  11. Nov 1, 2010 at 2:57 PM
    Taco Guapo
    Taco Guapo Lurker
    Carefree AZ
    09 AC 4X4 2.7L
    Bone stock
    This is a joke right? After you mount your roll bar you can grow some sideburns, get a big chip on your shoulder, and drive around looking like Lee Majors.
    Better just to keep the wheels side down.
  12. Nov 1, 2010 at 3:06 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    To each his own.
  13. Nov 1, 2010 at 3:12 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I dont actually plan on rolling the truck. Thats not the point of my roll bar, i just like the look of them hence the reason i put it onto the bed. Plus if you only bolt it to the frame it isnt going to do much under tension of a rollover you need to weld it and the material of the bar had better be pretty heavy duty.
  14. Nov 4, 2010 at 4:27 PM
    MMazz365
    Michael
    NY
    TRD Off Road
    I'm now looking at building more of a headache bar. just from my rails up across the top of the rear window and down back to the other rail. should i see if i can put a piece of steel underneath the side rails and use bolts to kind of like clamp it down?
  15. Nov 4, 2010 at 9:14 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Metalmiller is making custom headache racks you might want to look at his stuff. pretty impressive. It might give you an idea on how he mounts them and such.
  16. Nov 5, 2010 at 6:52 AM
    mjp2
    NJ
    No need this time around. ;)
    :thumbsup:
