Alignment isuues number inside pleae help
Old 05-06-2011, 04:31 PM   #1
ColoradoTaco is a jewel in the roughColoradoTaco is a jewel in the roughColoradoTaco is a jewel in the roughColoradoTaco is a jewel in the rough
ColoradoTaco's Avatar
ColoradoTaco's Tacoma Gallery
Go my alingment done doesnt feel right.
I have LR UCAS
6-7" lift Icon coilovers
pro comp 6" drop brackett lift
33 duratracs
Heres the problen they still rub barley when turnig sharp left or right on the body mount. when driving it pulls to the right having to correct on steeringwheel to drive straight. Was told this was due to road crown.
My question is what should i tweek things to to fix above issues. Help me TacomaWorld your my only hope......
Old 05-06-2011, 05:14 PM   #2
Still not worthy!
Sawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud of
Sawick's Avatar
Air Force: Security Forces
Sawick's Tacoma Gallery
I wish I could get my #'s to look like yours. Mine are way horrid. If your BS isnt correct, it cuold be the reason why you rub on the Cab Mount. I know even with perfect alignment, I will still need to chop mine with my 5bs rim. I cant begin to chime in on what having your size lift does though. I only have a 2.4" lift on mine.
Old 05-06-2011, 07:19 PM   #3
McBride513 is on a distinguished road
McBride513's Tacoma Gallery
try switching your front tires
Old 05-06-2011, 07:45 PM   #4
chris4x4's Avatar
chris4x4's Tacoma Gallery
Put your caster up to 3.1*
Old 05-06-2011, 10:59 PM   #5
thanks chris how do i fix the pull to the right (road crown) or do i live with it cause my tires are big a grab the road more.
Old 05-06-2011, 11:22 PM   #6
chris4x4's Avatar
Add more Caster to correct for the pulling.
Old 05-07-2011, 05:59 AM   #7
Largefarva is on a distinguished road
Navy: Nuke Electrician
Largefarva's Tacoma Gallery
I was told that the caster should be around .5 or so higher on the right to compensate for the pulling to the right (because of crowned roads)....is this true?
Old 05-09-2011, 04:23 PM   #8
Im confused caster at 3.1 will fix both the rubbing isssue and the pull to the right (Road Crown) is this correct?
Old 05-09-2011, 04:54 PM   #9
chris4x4's Avatar
It will help.
Old 05-10-2011, 06:15 PM   #10
It will help.
thanks chris ill give it a try and let you know i have read so many of your posts. I put high stock in your opinion.
Let's talk about alignment (keeping alignment) Mxpatriot Long Travel Suspension 6 10-21-2010 12:54 AM
Part Number for blanks on the dash? (Pics inside) vg05 2nd Gen. Tacomas 1 10-10-2010 05:02 PM
Number kennywood Buy / Sell / Trade 9 02-03-2010 09:43 PM
Calling all alignment gurus, opinions on my alignment numbers STLTaco09 Technical Chat 10 07-12-2009 10:44 AM
What's the number for TW.com? LonghornTaco Technology 5 02-26-2009 10:56 AM
