Air filter replacement
Discussion in 'Technical Chat' started by edubb, May 23, 2011.
  1. May 23, 2011 at 9:56 AM
    edubb
    edubb [OP] Member
    Texas
    08 prerunner trd sport
    What is the best replacement air filter for 2008 trd?
  2. May 23, 2011 at 9:59 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I like to say OEM but thats just me.
  3. May 23, 2011 at 10:04 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    Drop-in filter? AFe Pro Dry-S PN 31-10114
    The other filters like TRD, K&N, etc. require periodic oiling to work. Never liked where the oil would be going...
  4. May 23, 2011 at 10:07 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    I got the K&N air filter and no complaints here..
  5. May 25, 2011 at 2:43 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I've never owned a vehicle that didn't have an oiled K&N air filter in it.
  6. May 25, 2011 at 2:45 PM
    tommyc
    tommyc Well-Known Member
    tommy
    4X4 SR5, TRD
    Dude stay oem, there are better mods to spend your money on.
  7. May 25, 2011 at 2:59 PM
    techtalk
    techtalk Member
    you can get a K&N filter or a TRD filter. Both work great. You can always get a factory one or aftermarket OEM. you will get a little more power out of the TRD and K&N filters. They will cost more money but they're re-usable. the stock ones you throw away
  8. May 25, 2011 at 3:28 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Afe pro dry s ...
  9. May 25, 2011 at 3:40 PM
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    4.10 gears, sliders, and lots of buttons.
    For best filtering, you cant beat the OEM. For best flow, Nothing. The difference between the OEM filter and NO filter at all, is about 1.5 hp. So, if your thinking about changing the filter for a more "performance" filter, foget it.
  10. Jun 3, 2011 at 8:47 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Would all these suggestions apply to a first gen as well?
    I had K&Ns for my motorcycles. Didn't mind cleaning and oiling them once and a while. Not sure if I want to worry about it on a car though. How often do you have to clean and re-oil K&Ns for Tacos?
  11. Jun 3, 2011 at 9:12 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    incorrect. I found the Prodry was one of the best bang for buck upgrades you can buy. I also studied how filters are made and what their filtering values are, and theres no way I would use the stock fibrous-like POS ever again
  12. Jun 3, 2011 at 9:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The best oil samples I have had, have been when using the OEM filter. Not sure why you think they are bad......
  13. Jun 3, 2011 at 10:08 PM
    x2468
    damn... who to believe... idk
  14. Jun 4, 2011 at 5:05 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Well dont believe me because Im an idiot lol
  15. Jun 4, 2011 at 6:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not calling you an idiot, just wondering where you get your info. I dont think I could count how many filters I have tested, and everytime I have used the OEM filter, my samples came back with less silica levels in the oil. Even Fram OEM replacements have filtered MUCH better than the cleanable "High Flow" filters. The only way to get a higher flow, and more filtering, is to make the filter larger. MUCH larger. To add, given the filter size, you wont see much (if any) gains in mpg, or performance even if you ran no filter.
  16. Jun 4, 2011 at 7:52 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    oh I know, I ment really, sometimes Im an idiot lol
    But not, we just did a section on filtering air for furnaces. The material used in normal pleated filters was apparently not as good as higher end filters (im guessing AFE/K&N etc). I remember because I got the answer wrong on the pre-test because I figured exactly what your saying and was wrong. If you did tests though, Im going to mention that because nothing beats hands on
  17. Jun 4, 2011 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Filters for Furnaces are much different. A K&N filter for an auto aplication is a single layer gauze filter. It relies on the oil to capture the dirt particles. Being as it has shallow pleats, and a porous structure, its filtering ability for fine dirt particles is marginal. The OEM filter has a more dense filter media, and much deeper pleats. The surface area of the media is huge. This gives good air flow, and the media density give superior filtration.
  18. Jun 5, 2011 at 11:46 AM
    x2468
    well. im sold.
  19. Jun 5, 2011 at 11:50 AM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    The Amsoil EA Filter is the best. It's cleanable and lasts four years.
  20. Jun 5, 2011 at 12:01 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    @ADSracingshocks - F 3 point ohh / R 2.5 - w/clickers @camburgracing - uniball UCA @rigidindustries - 40" amber/white split, Dually XL, D2 @coopertires - 35/12.5/17 STT MAXX @bayareametalfab - low pro bed rack @toyotausa - 17" rock warrior @sdhqoffroad - rock sliders, a-pillar @hondogarage / @apple / @gaiagps / @dualgps- navigation @wheelersoffroadinc - superbumps
    For a first gen the best bang for the buck is going the deckplate mod with an aftermarket air filter.
