#21 | |
„ƃoɟ ɹnoןǝʌ ǝɥʇ„ :ɐʞɐ
perfect and its easy to add the ground from the switch assuming he has a lighted switch
__________________
![]() UNBREAKABLE FABRICATION
#22 | |
Carolina Alliance: Redneck Division
__________________
i am WILL --my ride=04 tacoma trd 4x4 double cab, v6, auto,deck plate mod, grey wire mod, billy 5100's all the way around,black low-pro uws toolbox, black steelies,blacked out emblems, mag light mod,wheelers/alcan springs, ome 881 coils, braided stainless brake lines, polyurethane bushings,dynomax super turbo/slash cut tip-blacked out,chrome deleted bumpers via herculiner bed liner,color matched bedlinered tailgate, camo seat covers,sockmonkey decals,husky floor liners and still to come....15 inch wheelers steelies and gy wrangler mtr's!!!http://s202.photobucket.com/albums/aa269/tacomaman06/ ![]() www.myspace.com/goodolboy1979 |
#23 |
well, I got it working preliminarily (with all the wires under the hood). Now, I'm running the wires to install the switch.
#24 |
are you going ahead and using the relay?
__________________
#25 |
#26 |
good deal.
well, im crashing out......hunting early am!!! let me know how the wiring turns out man!!
__________________
#27 |
Alright. I got it wired up and the switch in the cab, but I have NOWHERE to mount the switch unless I just drill into the dash randomly.
I had planned on mounting the switch in the only open space I have: ![]() However, once I finally got to the point where I could get this blank out (I took apart 3/4 of the dash and center console!) I found that it really isn't suitable for mounting this switch. Or any switch for that matter... Plus, I don't have a drill bit large enough to fit the switch anyway, so I'll have to figure something out tomorrow. Also, these lights don't seem nearly as bright as I remember them. They are the Hella 500FF(http://www.autoanything.com/lights/69A1325A0A0.aspx), but I guess I shouldn't expect much out of lights that were only $65/pair at Walmart. Off to bed. |
#28 | |
__________________
#29 |
Northern Alliance Ally
The way you have the lights wired, just make sure the switch can carry the full electrical load of the lights. That's one of the main advantages for using a relay. With a relay the switch is carrying almost no current so you can use a tiny, better looking switch. There is a reason the switch that comes with the lights is big...
#30 |
Doomsday squad:Rampage
I have the hella 500's and I skipped the relay. they work just fine.
__________________
Im from Texas. |
#31 | |
How is the brightness on your 4 lights? Also, did you use the supplied switch or did you get a different one? |
#32 | |
#33 |
I am very satisfied with the brightness of my lights. I have the middle two straight ahead and the side ones pointed out a little to see whats on the sides of the road. those along with my HIDs light up everything great!
I am using the switches that came with them. I mounted them in the little storage compartment on the left of the wheel under all the factory switch places. I popped it out, cut out two holes in the back of it and mounted them. Ill take a pic here in about 30 mins when i got to lunch
__________________
Im from Texas. |
#34 |
gotcha!! i forgot you had all the added options that the 06 i had didnt have. i had 3 open spots there.
__________________
#35 |
__________________
Im from Texas. |
#36 |
