Access Cab rear door panels
Old 07-18-2011, 07:44 PM   #1
BigDan [OP] BigDan is offline
BigDan is on a distinguished road
BigDan's Avatar
BigDan's Tacoma Gallery
Send a message via Yahoo to BigDan
My 2011 access cab does not have speakers in the rear doors therefore, no speaker screens in the trim panel. Do earlier 2nd Gen models have speakers in the rear doors? If so, will a earlier door trim panel with OEM speaker screens mount to my 2011 doors? Will there be a color match problem?
I have installed round speakers in the doors using the screens that come with the speaker which looks kinda cheap.
Old 07-18-2011, 11:48 PM   #2
JKD JKD is offline
JKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shedJKD is one of the sharper tools in the shed
JKD's Avatar
JKD's Tacoma Gallery
Yes, earlier years did have speaker grilles; not sure on the color-match problem. I assume you're just replacing (in a diff. location) the stock ceiling-mounted rear exciters?
Old 07-18-2011, 11:58 PM   #3
Somebody call for a Wambulance?
Mitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shedMitch is one of the sharper tools in the shed
Mitch's Avatar
EMS: Paramedic
Mitch's Tacoma Gallery
My 2007 has the speakers on the rear doors. Would the colors be that different from 2005-2011?
Old 07-19-2011, 08:27 AM   #4
BigDan's Avatar
No, I disconnected the exciters and installed "Punch" rounds in the rear doors.
So, now you have answered that earlier models have screens. I wonder what, if any mounting problems I will have. In other words, is the panel with grille screens gonna attach to my doors?
Old 07-20-2011, 09:32 PM   #5
Jumper's Leds
csjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shedcsjumper2003 is one of the sharper tools in the shed
csjumper2003's Avatar
Navy: 2nd class petty officer
csjumper2003's Tacoma Gallery
It's the same panel just no speakers and the sons a bitches are really expensive. U gotta go pre 09
Old 09-13-2011, 04:15 AM   #6
2011 Tacoma Access Cab TRD 4x4
tacomaSquid2011 is on a distinguished road
Navy: Aviation machinists mate at VP-30
tacomaSquid2011's Tacoma Gallery
would you mind posting a picture of your rear doors with your speakers mounted? And more information on how you mounted and what not.
Thank you for your time.
Old 09-13-2011, 08:45 AM   #7
Jumper's Leds
Like this are the pre 09. I have now changed mine out. You have to run wires through the door for powering the speaker install speaker using original bracket or aftermarket, and the older panels fit perfect. Like I said earlier they are a little pricey and rare but they are worth it.
Old 09-17-2011, 06:48 AM   #8
BigDan's Avatar
Pics of my installation.
Access Cab rear door panels-audioinstalldoorstructure.jpg   Access Cab rear door panels-audioinstallrearspeaker.jpg
Old 09-23-2011, 11:54 AM   #9
What size are those "punch rounds" did you get the 6.5" ? I have the RF Punch 6.5" components in my front doors and a RF punch 200 watt 2-channel pushing them. - shame will have to get a multi chanel soon. Also from the picture you posted. It looks like the door DOES have a factory mount in the metal frame for a speaker? Did you have to make or use a bracket? I made brackets for my front door out of 1/2'' MDF for the 6.5" and 1/4" MDF for the tweeter. Dremel tools are AWESOME! I had a lot of fun and enjoyed making those.
Thanks for your time guys!
Old 09-23-2011, 02:16 PM   #10
Jumper's Leds
I put infinity in mine. And used factory 6.5 speaker and used the surround of it to mount 6.5 in door
Old 09-25-2011, 03:31 PM   #11
BigDan's Avatar
The front doors are Punch P1694 6x9" and T1TS Tweeters. The rears are P152 5 1/4" rounds. Amp is a P400.4.
The metal part of the rear door does have a hole to mount a speaker BUT it does not align with the plastic panel. Note the panel is curved in front of the speaker mount. It order to get the speaker to mount where the plastic is level, the hole in the metal had to be opened up about 1 inch.
Old 09-26-2011, 03:07 AM   #12
i did a component set in the front. Do you think they 5.25" would look better than the 6.5" ? I only deal with Fosgate. I have a Punch 200 2 channel AMP that 400 watt amp how much does it put out at 4ohm x 4? And also, any tips on removing the back door panels? I have not found any how-to's yet.
Thanks!
WTB Front inner door panels for an access cab Grey 05xr 2nd Gen Tacoma Marketplace 6 01-06-2012 01:25 AM
Access Cab Rear Door Panels Yota Toy 2nd Gen. Tacomas 3 11-09-2011 09:13 AM
how do you remove door panels on an access cab 2nd gen tacoma? kauairandall 2nd Gen. Tacomas 3 05-10-2011 06:42 PM
LTB Crew Cab Rear Door Panels stormtrooper37 Buy / Sell / Trade 0 03-16-2011 08:01 AM
Has anyone ever attempted to replace the Access Cab's Door Panels in a Tacoma? ChaseUA 2nd Gen. Tacomas 9 08-03-2010 09:18 PM
