Water pump - gasket or RTV?
Old 08-05-2011, 03:30 PM   #1
Enigmaaron [OP] Enigmaaron is offline
All your soul are belong to us
Enigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shedEnigmaaron is one of the sharper tools in the shed
Enigmaaron's Avatar
Enigmaaron's Tacoma Gallery
Changing my timing belt tomorrow and doing the water pump (and everything else in there) at the same time. The water pump came with a gasket (see below). All the directions I'm reading up on say to use RTV. Sounds like Toyota switched to a gasket towards the end of the 1st gens lifetime
Seems like the gasket would be a hell of a lot easier (I know I would get RTV all over the place). Anyone have opinions?
Old 08-05-2011, 03:33 PM   #2
horwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shedhorwitzs is one of the sharper tools in the shed
horwitzs's Avatar
horwitzs's Tacoma Gallery
I agree. If you have a gasket then I don't know why you'd bother with RTV.
Old 08-05-2011, 05:11 PM   #3
McBride513 is on a distinguished road
McBride513's Tacoma Gallery
you can put a little RTV on the gasket to hold it in place while you install the water pump
Old 08-05-2011, 06:04 PM   #4
slo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shedslo13zx3 is one of the sharper tools in the shed
slo13zx3's Avatar
slo13zx3's Tacoma Gallery
rub a super light coat of gray rtv on the block and water pump super light and use the gasket
Old 08-07-2011, 02:33 PM   #5
Enigmaaron's Avatar
Thanks for the tips guys. When I pulled it all apart I found my truck had the same metal/rubber gasket as the one I got with the replacement in the pic above. There wasn't any RTV on in there so I decided to just put it back the way it was without any RTV. I held a couple of bolts through the water pump as I put it on to hold the gasket in place.
Old 08-07-2011, 02:35 PM   #6
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
Yeah my 2001 had no gasket, just RTV. I like the gasket better.
Old 08-08-2011, 04:30 PM   #7
Redbandit is on a distinguished road
Redbandit's Avatar
Redbandit's Tacoma Gallery
Damn. Pulling my timing belt and water pump at this same moment. Good luck with yours!
Old 08-08-2011, 05:31 PM   #8
skytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shedskytower is one of the sharper tools in the shed
skytower's Avatar
Navy: Gunners Mate
skytower's Tacoma Gallery
That gasket has it's own rubber seal on the paper gasket. No RTV is required or needed. A good rule, like you already found, is to put on what was taken off; that only applies to known factory parts.
Old 08-20-2011, 11:47 PM   #9
2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed2000GTacoma is one of the sharper tools in the shed
2000GTacoma's Avatar
2000GTacoma's Tacoma Gallery
you buy an oem water pump?
Old 08-21-2011, 05:13 AM   #10
Enigmaaron's Avatar
It was an Aisin water pump. Don't know if that's OEM or not.
Old 08-21-2011, 11:40 AM   #11
no trouble so far working good?
Old 09-26-2011, 06:13 PM   #12
Enigmaaron's Avatar
Just noticed I never responded to this. A little late, lol. But I'm over 2000 miles since the change and everything's running good.
Water Pump 2000GTacoma 1st Gen. Tacomas 29 12-18-2011 04:53 AM
water pump tool Bartaco 1st Gen. Tacomas 7 05-12-2011 04:08 PM
Water pump! RecklessTaco 2nd Gen. Tacomas 7 05-05-2011 05:25 PM
Matt's Water Pump Gregero Southern California 20 05-05-2011 03:10 PM
Which water pump? Jmajors 1st Gen. Tacomas 3 01-19-2010 06:10 AM
