PrezidentRedz' 2000 Tacoma 4x4
2000 V6 PreRunner rotors
Old 11-02-2008, 07:21 PM   #1
wonl2 is on a distinguished road
wonl2's Tacoma Gallery
Went and had all of my belts replaced and cooling system flushed for my 90,000 mile service at a Toyota dealership. 2000 V6 PreRunner. The water pump was also replaced. Was told that the front pads had about 20% of the pad left and the rotors need to be replaced. Just replaced the pads 2 years ago. I have 86,000 miles on the truck. I had approx 60,000 miles when I replaced the pads. Was also told that the rotors need to be turned and this would make the thickness of the rotors too thin. I cannot see any gouges or grooves in the rotors. I read in my Haynes repair manual that there is a number on the rotors that states the minimal thickness for the rotors. Looked at the rotors when I took the wheels off and did not see any numbers stamped into the rotors. Where can I find the minimal thickness for my rotors. These rotors were never turned. I did measure the thickness and they were 0.864 and 0.859 thick. Do pads typically last 25,000 miles? Replaced factory pads with original Toyota pads. Any recommendations on pads/rotors. I plan on replacing them if/when needed.
Thanks in advanced
wonl2
Old 11-02-2008, 07:47 PM   #2
harris.jasonm is a splendid one to beholdharris.jasonm is a splendid one to beholdharris.jasonm is a splendid one to beholdharris.jasonm is a splendid one to beholdharris.jasonm is a splendid one to beholdharris.jasonm is a splendid one to behold
harris.jasonm's Avatar
Marines: Advisor Instructor 0311
harris.jasonm's Tacoma Gallery
If the rotors do not have grooves that will catch the finger nail when run across them and the steering wheel does not shake under heavy breaking then you rotors are fine. If they have never been turned them you should be able to turn them with no problem. I think new ones are less than $50.00 each anyway. As for the front pads thats 70% of your breaking power so thats why they wear. Now as for changing the pads, man they only take 10 min per side. I have changed the ones on my 97 3 or 4 times over the years. Just two slide pins and a retainer clip. Take the top caliper bolt out with the brake fluid cap off and use the old pads to push the caliper back and drop in the new ones. Pump the breaks after both sides are done and your good.
__________________
I am Jay
The truck is an 07 Access Cab TRD Off Road 4X4, 6 speed, 4.0 V6.
Upgrades: Bug Shield, Bed Mat, Toyota Tool Box, Seat Covers, Weather-Tech Floor Mats, Leather Arm Rest, Airaid Intake, Kenwood Deck with 6X9's in front and 6.5's in back. TRD Shifter Knob, Black Nerf Bars, Grille-Craft grille and Skid Plate.
Old 11-02-2008, 07:50 PM   #3
Carolina Alliance: Redneck Division
tacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond reputetacomaman06 has a reputation beyond repute
tacomaman06's Avatar
tacomaman06's Tacoma Gallery
you should be able to turn your rotors and they will more than likely be fine, although, at 86k....you could be getting close to time for new rotors, especially if they have never been turned when you installed new brakes. rotors are relatively cheap(autozone) unless you get performance rotors like power slot or something. its always a good idea to turn rotors anytime you install new pads...no matter if they feel ok and you cant feel any ridges in them.
__________________
i am WILL--my ride=04 tacoma trd 4x4 double cab, v6, auto,deck plate mod, grey wire mod, billy 5100's all the way around,black low-pro uws toolbox, black steelies,blacked out emblems, mag light mod,wheelers/alcan springs, ome 881 coils, braided stainless brake lines, polyurethane bushings,dynomax super turbo/slash cut tip-blacked out,chrome deleted bumpers via herculiner bed liner,color matched bedlinered tailgate, camo seat covers,sockmonkey decals,husky floor liners and still to come....15 inch wheelers steelies and gy wrangler mtr's!!!
http://s202.photobucket.com/albums/aa269/tacomaman06/
signature by piercedtiger
www.myspace.com/goodolboy1979
Old 11-02-2008, 07:51 PM   #4
As for pads get the Bendex ones or allied / bendex, same brand. As for seeing how much life you have left on the ones you have there are little metal tabs at the back of the pad. This is an indacator. If you hear them start to squeal then they need to be replaced. Normally about 3/16 of an inch of the pad is left when you need to put in new ones. If you take off the tire and check them make sure you look at both the front and back pad! Sometimes they back one wear a little faster.
__________________
I am Jay
Old 11-02-2008, 07:52 PM   #5
And as Will stated if you have the money and time always turn your rotors when replacing the brakes. Good catch Will. Most machine shops will turn them for $10 to $15 each.
__________________
I am Jay
Old 11-02-2008, 07:56 PM   #6
yeah man... i speak from experience as for turning the rotors. i ran outta time to have rotors turned one day on the wifes old car.........about a week later.....the pads on the driver side were glazed over and shaking and pulling when you hit the brakes. turned out the rotor was warped a little and the pads didnt grab right on it. just good insurance to turn them rotors.
__________________
Old 11-02-2008, 08:03 PM   #7
Yeah I hate doing brakes on a Honda. The caliper wants to fight you unless you have the tool to turn the pistons back. Wonl2 make sure you use brake clean to spray everything out if you do your own other than than use the orange break grease on your shims or they will raise all kinda hell.
__________________
I am Jay
Old 11-02-2008, 08:07 PM   #8
i have used that orange stuff a few times, but something i have found that works alot better,imo of course, is a brake grease from crc. you use it on the backing plates, slides and clips...basically all metal contact points. that stuff works awesome. you can get it at autozone for around 5 bucks.........and i have done 6 brake jobs with it and still have more than half the can left.
__________________
Old 11-02-2008, 08:11 PM   #9
Are you talking about the spray can? I have not tried it because I have about half a bottle of the messy orange crap. If so I will pick up a can. Seems like I am throwing in a set of front pads every other weekend for a case of beer.
__________________
I am Jay
Old 11-02-2008, 08:16 PM   #10
Bender The Pimp
genxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond reputegenxer36 has a reputation beyond repute
genxer36's Avatar
genxer36's Tacoma Gallery
Send a message via Yahoo to genxer36
Also by doing the brakes yourself. You only have to buy pads one time. They have a "lifetime warranty", meaning when you need new ones you take the old pads back to the auto parts store & they swap them out for free.
I had a Jeep Grand Cherokee that would go through brakes. I kept an extra set of pads & 2 extra rotors on hand (since it was my only vehicle). When I did the brakes, I would put my extra set on. Take my rotors to be turned for next time. And swap out my pads at Autozone. Then I was set for the next time.
__________________
2005 Tacoma DC Pre Runner, 20" Enkeis with 265/50/20 Nitto NT420 tires, K&N air filter,In-channel vent visors,A.R.E. Tonneau cover, Removed secondary air filter. 103,000 miles & still going strong!
Old 11-02-2008, 08:16 PM   #11
nah...not a spray can. its in a small plastic bottle/can with a screw off lid that has a brush made onto it. that stuff works awesomely bro. if you try it...let me know how you like it!
__________________
Old 11-02-2008, 08:31 PM   #12
Will do, thanks for the info. I'll pick up some this week. CRC makes some good stuff.
__________________
I am Jay
Old 11-02-2008, 08:34 PM   #13
no prob bro!!! hell...i use alotta the crc stuff too man.......throttle body cleaner, brake grease, electronic component cleaner....lots o stuff.
__________________
Display Modes
99 rotors? devilsalmostfree Buy / Sell / Trade 3 11-02-2008 06:29 AM
F/S 2002 PreRunner SR5 in Middle TN asjwalsh Buy / Sell / Trade 2 07-22-2008 07:04 AM
turning rotors!!??!!?? tacomaman06 2nd Gen. Tacomas 26 01-12-2008 07:29 PM
NEW XR ROTORS Installed TheArkansas"X" 2nd Gen. Tacomas 4 09-07-2007 04:55 AM
EBC brake rotors Mat-taco06 Performance and Tuning 3 08-03-2007 08:19 AM
Copyright © 2009 Tacoma Forum
