Grillcraft install
Discussion in 'Technical Chat' started by chadderkdawg, Oct 28, 2011.
  1. Oct 28, 2011 at 6:25 AM
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Got my grillecraft installed today. Here is a little step by step.
    Remove your grill and get it on a table of some kind.
    Start cutting out the crossbars and center section, I used a dremel multimax.
    This is what you should be looking at now.
    Next, place the grillecraft grill into the shell from the frontside, mark the mounting holes with a pencil and drill them out using a 3/16 size bit.
    Insert the screws from the inside and put the backing plates on the opposite side and snug everything down, I used an open ended wrench, 1/4 inch.
    Remount your grille and step back to admire your great work!
    Thats all for now, go big red ;)
  2. Oct 28, 2011 at 6:32 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I doubt it will, if I was going to go through the process though, I would actually fill them in, smooth it out, and paint over them. Not really a huge fan of the triangles. I will probably do the bumper though.
  3. Oct 28, 2011 at 6:32 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Cough ug cough
  4. Oct 28, 2011 at 6:41 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Yea I did see that, I thought of it first though!! Haha, I definitely dig the look.
