Milk shake diff fluid?
Old 11-13-2011, 03:36 PM   #1
Malcolm3.4 [OP] Malcolm3.4 is offline
Malcolm3.4 is on a distinguished road
Malcolm3.4's Avatar
Malcolm3.4's Tacoma Gallery
I replaced all my fluids today and was greeted by a milky brown discharge coming from my rear diff.[IMG][/IMG] Thinking some water got in thru the breather. Ideas? All the good looking diff fluid in the pan is from the front diff and transfer case. Guess it might be time to do the breather mod.
Old 11-13-2011, 03:36 PM   #2
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
That would be water or it's aerated. Did you drive it right before you changed it?
Old 11-13-2011, 03:38 PM   #4
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
I drove mine right before changing the rear diff fluid and it was not aerated like that. Im betting it's water.
Old 11-13-2011, 03:40 PM   #5
Feed him a hammer, he'd crap out nails.
Dark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shedDark_Taco is one of the sharper tools in the shed
Dark_Taco's Avatar
Dark_Taco's Tacoma Gallery
Agreed with above....it's water. Check your axel seals and the previous mentioned diff breather.
Old 11-13-2011, 03:51 PM   #6
Malcolm3.4's Avatar
I was thinking axel seals also. Both drums are dry and the pinion seal area. If water can go in, wouldn't gear fluid be coming out?
Old 11-13-2011, 03:52 PM   #7
:POOPCORN:
98tacoma27's Avatar
Marines:
It can get in through the breather where the oil rarely gets too
Old 11-13-2011, 05:30 PM   #8
David K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shedDavid K is one of the sharper tools in the shed
David K's Avatar
David K's Tacoma Gallery
How? This is what I understood and discovered...
The stock breather is a spring loaded, one way (out only) check valve... releases hot expanding gasses only if they build up pressure greated than the force of the spring. The breather is shut closed to the outside, other wise.
The reason we do the rear breather mod. is to put a true (2 way) breather on the diff., but up high, like it is on the front diff.
This way, during negative diff. pressure (caused when driving into a stream or puddle deeper than a foot) water won't suck into the diff. past the axle seals.
This makes the breather dual purpose:
1) Allow expanding gasses out.
2) Break the vacuum with fresh air to prevent the siphoning-in of dirty water.
Old 11-13-2011, 05:35 PM   #9
Banned
Springs get weak over time.
Old 11-13-2011, 05:36 PM   #10
:POOPCORN:
98tacoma27's Avatar
Marines:
..........and you've tested the seal to ensure it, in fact, does keep water out?
Old 11-13-2011, 07:33 PM   #11
Old & Forgetful
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
Originally Posted by nmcqueen280 View Post
when does it break the vacuum?
It doesn't matter.... It's NOT a completely sealed system & can't be.
If you've ever looked at one of those breathers...it's a cheap monkey metal looking cap ontop of a plastic thing-a-ma-bob which appears to have springing motion. It only really protects from overspray/rain.
By the looks of your avatar...you go offroad with your truck. If you sink your diff in water/mud, you're gonna get water inside that breather.
Everyone who takes their trucks offroad - needs to extend their diff breathers! Cheap & easy insurance to protect your diffs!
Old 11-14-2011, 10:35 AM   #12
David K's Avatar
When a HOT differential is driven into COOL water...
The stock breather is really a VENT, that takes some pressure to open the spring loaded check valve... The stock breather does NOT allow anything to get INTO the diff.
So, the muddy water MUST get into it via another place... and that other place would be the axle and driveshaft seals.
By using the same breather that Toyota uses on the FRONT, for the REAR (with this mod), we provide a 2 WAY breather, up high... so hot gasses can escape (as before), but also no vacuum can be created to suck water past the axle seals either... since this true breather will let air rush in during the event.
Old 11-14-2011, 10:42 AM   #13
The Man!
JLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shed
JLee's Avatar
JLee's Tacoma Gallery
X2 I did a valve cover filter for my breather in the engine bay No no vacuum can be created in my setup.
It way like 6 bucks on Ebay
Old 11-14-2011, 02:14 PM   #14
:POOPCORN:
98tacoma27's Avatar
Marines:
If you think this will keep water out, you're nuts.
Old 11-14-2011, 02:18 PM   #15
chris4x4's Avatar
chris4x4's Tacoma Gallery
When a HOT differential is driven into COOL water... .
Thus causing the air and oil in the diff to cool, and creating a vacuum environment, and when it equalizes, water can get in. There is no magic membrane that allows the pressure to equalize, and not let in contaminants. And if the diff were sealed, then as the pressure increases as it gets hot, the oil would blow past the seals......and leak onto the drums, causing a condition that, when the local neigbor kid runs in front of you, and you apply the brakes to avoid him/her, you would loose control of your truck, hitting a house and bursting into flames. The polutants from the resulting fire would contaminate the atmosphere, throwing the planet into an ice age, or global warming it to the point that everything burns in flames......depending on what theory you subscribe to.
NOTE: only some things I posted are true. Hint- the global warming/cooling part is false........or is it.....
Old 11-14-2011, 02:20 PM   #16
chris4x4's Avatar
Old 11-14-2011, 02:24 PM   #17
:POOPCORN:
98tacoma27's Avatar
Marines:
If that would keep water out, then the diff breather relocate mod is a waste
Old 11-14-2011, 02:30 PM   #18
David K's Avatar
I am not nuts (on this anyway).
The rubber disc sits on the opening, and the spring pushes down against it. You can blow air out of the diff side with some force to open the valve... as in hot gasses escaping the diff..
However, unless that spring and rubber disc is removed, you cannot blow air into the diff. Blow as hard as you like! The water is NOT getting in here with that disc and spring in place. It gets in past the axle seals.
Putting a 2 way breather in place of this one way one in your picture (up higher at the end of a hose), is what eliminates a vacuum that would cause water to get it. Why does Toyota do this on the front diff., if not true? (of course, why don't they do it on the rear??!!)
Old 11-14-2011, 02:30 PM   #19
Banned
I just don't know why they don't seal the diffs. I'm going to weld mine shut.
live via
Old 11-14-2011, 02:32 PM   #20
braaap
steve o 77's Avatar
who cares how the water gets in there, all that matters is we all know the fix
Rear diff fluid accesscab Technical Chat 10 12-22-2011 02:21 PM
diff fluid help viperfella 1st Gen. Tacomas 8 06-13-2010 06:15 PM
Trans fluid and Diff fluid.. fpradojr36 1st Gen. Tacomas 3 05-06-2010 06:13 PM
what diff fluid? LBtaco 2nd Gen. Tacomas 7 01-05-2010 06:07 PM
what diff. fluid to use??? TRDfarmerTN 2nd Gen. Tacomas 5 12-13-2009 10:26 AM
