4 cylinder TSB's
Old 11-14-2011, 07:29 PM   #1
Joe's Auto Detail
tacomacntry is on a distinguished road
tacomacntry's Avatar
tacomacntry's Tacoma Gallery
Send a message via AIM to tacomacntry
4 cylinder TSB's
I have recently aquired a 1998 4 cylinder single cab 4x4...its a 5 speed 2.7. I have a low rpm power loss.anywhere under 25-3000 rpms the truck is a little sluggish and has a very very faint hesitation. I understand that you can not expect much power from a 4 cylinder...but this truck should not have this problem...the plugs and wires are new, replaced with factory parts..fuel filter is clean, fresh oil change, all fluids are new and at the correct level...the truck runs fine otherwise while cruising at any speed or above 3000 accelerating..I was wondering if anyone is aware of any TSB's this year truck may have had...the previous owners were older and may not have been aware of any recalls or bulletins posted..any info much appreciated in advance!
Old 11-14-2011, 07:49 PM   #2
TW's Official anti body-lift pundit
TacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shed
TacoMX's Avatar
EMS: Paramedic
TacoMX's Tacoma Gallery
i dont think they are any active tsb's for the older 1st gens..
how many miles on your truck?
Clean your throttle body and clean the MAF and see if that helps. At 175k my throttle body looked like the inside of a coal mine...
Old 11-14-2011, 07:51 PM   #3
Joe's Auto Detail
throttle body is mint! and so is the MAF i took apart the whole intake and cleaned it completely mint! even a very slight coat of wax in there to let dry overnight! haha its got 118k!
Old 11-14-2011, 07:58 PM   #4
TacoMX's Avatar
EMS: Paramedic
hmmm...
My truck had a slight hesitation with a cracked exhaust manifold, take it look at it.
Also try some seafoam through the gas tank and intake vacuum line.
Old 11-14-2011, 08:06 PM   #5
Joe's Auto Detail
oh man! i got a cracked manifold....i sealed it though....with that weld shit! its dead quiet now...but i did the seafoam...no help! and i use lucas fuel treatment every tank...umm gonna cut the cat out too...
Old 11-14-2011, 08:14 PM   #6
TacoMX's Avatar
EMS: Paramedic
do you think the cat is bad?
Old 11-14-2011, 08:15 PM   #7
Joe's Auto Detail
thats the last thing i can think of....the engine has no tick...or knock, or noise...it runs sooooooooooo mint! but its got that low end lag to it...then clears up perfect...i dont get it..
Those of you with the 4 cylinder... Rich8419 2nd Gen. Tacomas 70 12-27-2012 06:02 AM
5100's @ 1.75 w/ TSB & 5100's @ .85/Eibach coils w/ TSB springs and TSB AAL huntark03 Suspension 0 09-27-2011 01:50 PM
Which is cylinder #6? Tacomanator 2nd Gen. Tacomas 5 12-22-2010 04:43 PM
4 cylinder or 6 cylinder? burni44 4 Cylinder 17 06-21-2009 11:55 AM
2.7 four cylinder Canopus Technical Chat 3 02-03-2009 10:19 PM
