2010 Prerunner 4Cyl, 5spd manual Transmission Oil Change
Old 11-21-2011, 05:52 PM   #1
ADVBedouin [OP] ADVBedouin is offline
ADVBedouin has a spectacular aura aboutADVBedouin has a spectacular aura about
ADVBedouin's Avatar
ADVBedouin's Tacoma Gallery
It took me a while to find specs/info on changing out my 5spd manual Transmission fluids, so I thought I'd post a quick DIY, sorry no pics;
All you need is a drain pan, 2.7 qts of oil, a 24mm socket & a decent torque wrench for 27' lbs on both bolts.
-The drainplug is easy to see; bottom of the trans, passenger side, 24mm.
-The fill plug is also easy to see; driver side, just halfway up the back side, 24mm, just be sure you can crack it open before you drain out the fluid.
-I used Mobil-1 75/90w synthetic, & they come in long tubular bottles that make filling the trans easy. My trans now shifts noticeably quicker/slicker, albeit slightly more notchy, & I'm quite happy with it (30k miles).
-Just put an 8-10" long piece of .5" clear tubing on the pointed cap of the oil bottle, press it on very tightly, & you can squeeze in the 2.7 quarts easily.
-You can then screw the same cap/hose onto the other 2 bottles, & there's lots of room next to the drive shaft to hold the bottles above the fill hole & squeeze the oil in by hand.
-You do not need a pump for this & it only took me 20 mins start to finish for the entire process.
-Fill the trans until the 2.7 qts are gone, or until oil starts weeping out the fill hole.
-Torque the bolts to 27' lbs & you're done.
Old 11-21-2011, 05:54 PM   #2
it's about the off-road miles
tacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shed
tacokid09's Tacoma Gallery
nom nom nom
Manual Transmission oil change Manwithoutaplan 2nd Gen. Tacomas 100 08-15-2013 11:35 AM
Will a 4x4 Access cab 4cyl 5spd manual Tacoma meet my family's needs? Kravchenko 4 Cylinder 38 03-29-2011 03:26 PM
Transmission oil opinions for a 2010 2.7L 5spd ADVBedouin 2nd Gen. Tacomas 2 02-18-2011 02:33 PM
transmission issues (5spd manual) brandon121 2nd Gen. Tacomas 1 10-14-2010 07:50 PM
Tacoma Prerunner 4cyl - How do I change transmission fluid prerunnerSD 4 Cylinder 1 05-22-2010 12:35 AM
