spark plug color
Discussion in 'Technical Chat' started by Cobra69, Nov 16, 2008.
  1. Nov 24, 2008 at 11:35 AM
    #21
    Cobra69
    Cobra69 [OP] Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    Ok first pic is of my finger on the coil pack.........notice the wire to the right......that is the spark plug wire to the spark plug on the other side. Follow it to the plug. Also the side with the coilpacks the spark plug is underneath the coil............undo the bolt in the pic pull straight out, look in hole you"ll see the spark plug.
    Next pic is of two coilpacks .
    On the 2009 Model you might have 3 coilpacks or six not sure. Just look for the coilpacks and any sparkplug wire running away from it.
  2. Nov 24, 2008 at 12:30 PM
    #22
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    ummm...i dont see that on my truck, I'll try to post a pic on my truck, but is going to be dark out soon... damn winter time!
  3. Nov 24, 2008 at 12:36 PM
    #23
    Cobra69
    ok try to post a pic of each side for me to look at ill help out if i can
  4. Nov 24, 2008 at 5:23 PM
    #24
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The second gens are a little different, but just like Cobra said, follow the wires. The plugs are in the middle of the valve covers, 3 on each side.
  5. Nov 25, 2008 at 4:34 AM
    #25
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    i wont able to take a pic of my truck until thanksgiving day when I'm off.
    I get home too late to do anything. Sorry guys!
  6. Nov 25, 2008 at 4:58 AM
    #26
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Just so y'all know, I'm keeping an eye on this thread as I am interested in changing my own plugs at 30k miles, too. I appreciate all the help everybody is giving, and I'm looking forward to adding a wrinkle to my brain and some plugs to my truck as a result of this thread.
    Thanks again, TW.
  7. Nov 27, 2008 at 6:51 AM
    #27
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    the first pic is my hot truck,
    2nd pic should be the drive side of the engine and 3rd pic is driver's side engine... u mean the coil pack is that black knob on that engine block? sure looks a lot different than the 02 :confused:
  8. Nov 27, 2008 at 1:25 PM
    #28
    Cobra69
    Yup thats them..........undo the one bolt that secures it down and pull it straight out and you will find the plug in the hole.
  9. Nov 27, 2008 at 1:25 PM
    #29
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The coil pack is on the valve cover, not the block. It has the wires going into it.
  10. Nov 27, 2008 at 1:50 PM
    #30
    Cobra69
    Chris is right should have pointed that out also.........sorry I forgot you don't know what to look for.
    The last pic of the two black square things with the wire connected to it and one bolt attaching it to the vavle cover are your coil packs.
  11. Nov 27, 2008 at 2:17 PM
    #31
    MannyECG
    MannyECG MasterChief
    Tempe, AZ
    06 TRD Sport, 4x4, D-Cab, Long Bed
    K&N Air Intake, BFG A/Ts, N-Fab Nerf Steps, Tailgate Pop N Lock
    Ok, so after you undo the bolt and pull it out, how do you remove the spark plug? I tried it once and removed the tip but I still couldn't figure it out.
    Thanks!
  12. Nov 27, 2008 at 2:44 PM
    #32
    Cobra69
    Take one of your new spark plugs and fit it to your spark plug socket(i don't know if you have the same size as mine)if it does not fit take the new plug and go to the parts store find the right size spark plug socket) the spark plug socket has a rubber grommet in it that helps in holding the plug your removing as you draw it out of the hole, get a long and short socket extension use both or one with the socket, slide it into the hole over the sparkplug and remove the plug.
  13. Nov 27, 2008 at 5:02 PM
    #33
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    maybe I should have one my friend of a friend that are a mechanic to help me out, I'm afraid I'm going to F my car up!
  14. Nov 27, 2008 at 5:03 PM
    #34
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your pretty close to me. If you want, let me know, and I will come over and show you how to change the plugs. :)
  15. Nov 27, 2008 at 5:07 PM
    #35
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a 5/8ths spark plug socket will do the trick. the extensions are definitely needed too.
  16. Nov 27, 2008 at 5:20 PM
    #36
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Dude...You're killing me w/this.:Dlol...How far is close enough??:D
  17. Nov 27, 2008 at 5:23 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It depends on how busy I am. :D I prefer to help people that are in the same state, but exceptions have been made in the past. :)
  18. Nov 27, 2008 at 8:41 PM
    #38
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Note that if your spark plug socket doesn't have the rubber grommet, you can use a magnet (either a pen magnet or a magnet wrapped to a coat hangar with electrical tape) to lower in/remove spark plugs.
