Topping off your fuel tank
Discussion in 'Technical Chat' started by bowzerdoo77, Dec 4, 2011.
  1. Dec 4, 2011 at 7:37 AM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Ok I have jsut haerd some info about topping off your fuel tank when you fill up, they told me it puts strain on your fuel pump. Who else does it? and is it really bad for the pump.:D
  2. Dec 4, 2011 at 7:39 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    How could topping off your tank strain your fuel pump?
    I've heard that runnng it out of gas can hurt the pump.
  3. Dec 4, 2011 at 7:40 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    x2 its sucks up all the gunk from the tank
  4. Dec 4, 2011 at 7:41 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    That doesn't make any sense. The only way you can really damage your fuel pump is by running it dry, because there wouldn't be any fuel to cool it. How could adding fuel to your tank cause damage to the pump? The pump doesn't care if you add 2 gallons, or 20 gallons...all it does it pump fuel.
  5. Dec 4, 2011 at 7:43 AM
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    So I should keep it at half full/empty ?
    I always top it off. Always give it a few drops more after the nozzle clicks off on its own. I have done this for years with many different vehicles and never had a fuel pump issue. I did have a fuel pump go bad but on my fathers truck and I had filled it the day before. Coincidence as far as I'm concerned. My mechanic says the pumps always go bad when the tank is full. Never empty.
    :poking:
  6. Dec 4, 2011 at 7:45 AM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Thats what i was wondering how can preasure on the pump be bad for it? thats why i asked here.
  7. Dec 4, 2011 at 7:49 AM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    This ^^.
    The only "downside" to topping off is some aren't careful and spill fuel all over the ground... which obviously isn't bad for your fuel pump, it only pisses off the attendant/store employee. Costco I've noticed is really touchy about topping off, I've had some of the attendants yell at me for doing it. I tell them to F off, I'm careful :D.
    As always, running it low constantly will keep the pump hotter and could damage it over time. Plus, ze gunk! So I try to fill up before it goes below 1/4. That's the only thing I would ensure in respect to fill-ups.
    TL;DR - You won't hurt your truck topping it off... Just don't run it empty constantly.
  8. Dec 4, 2011 at 7:54 AM
    jandrews
    '09 FourDubDee TRD OR
  9. Dec 4, 2011 at 7:56 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You're basically saying "adding gas to my tank will damage my fuel pump." Does that make any sense to you?
  10. Dec 4, 2011 at 8:11 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Do not top off! There are vents and ports for California emissions in the filler neck. When the pump stops, don't put more in. This will allow gasoline to go down into the closed canister system damaging the filter. Then you'll be spending money for a repair. Happens all the time at my shop. This vent system allows fresh air to enter into the emissions system and pressurize for constant diagnosis while driving. It can set off your check engine lamp and can cause some intermittent spitting and sputtering. Just don't top off.
  11. Dec 4, 2011 at 8:15 AM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    WTF?
    Is this some Cali-only thing...? I've always topped off, every vehicle pretty much every tank. Never had a problem. My truck was even made in Cali...
  12. Dec 4, 2011 at 8:31 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    BAAAHAHAHA!! Jackie Chan! Someone put a quote on it!!
  13. Dec 4, 2011 at 8:45 AM
    hogeyphenogey
    Dave
    Agawam, MA
  14. Dec 4, 2011 at 8:52 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    there is no gunk in the tank.. my 86 had 8 or so holes from rust on the outside of the tank and when i dropped it and emptied it it looked just like it would have when it came off the line in 85.
    pics
    holes
  15. Dec 4, 2011 at 8:57 AM
    T-Rex266
    T-Rex266 Elon Musk Moderator
    I top off all the time...especially in the winter to prevent fuel lines from freezing. Hell, If ur running it low it's collecting debris and crap which WILL cost u repairs.
  16. Dec 4, 2011 at 9:01 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    OP do you mean the people that constantly try to get more and more gas in the tank after its filled up?
  17. Dec 4, 2011 at 9:02 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This ^^^ is all I've read on this subject .
  18. Dec 4, 2011 at 9:03 AM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    It's possible I'm just retarded, but I'm not sure why that document is supposed to convince me topping off is bad. You do realize how gas will settle because of all the air in the line going into the tank, right...?
    I'm not talking about topping up 15x so gas spills out all over the bedside, ground, and leg. That's dumb.
  19. Dec 4, 2011 at 9:09 AM
    hogeyphenogey
    Dave
    Agawam, MA
    Any time you top off, gas goes down the evap tube. Period.
  20. Dec 4, 2011 at 9:17 AM
    jandrews
    This. It also hurts my head when people want to change the fuel filters in their Toyota vehicles.
    Toyota designed their EFI system from the beginning to NEVER need a fuel filter change, and if you read up on how it was designed, it truly never needs to be, unless you're dumping creek mud down your gas filler.
    Here is why:
    http://www.supramania.com/forums/content.php?121-The-great-fuel-filter-myth
