2012 4.0 6SPD 4WD -Ticking in engine, clunking in Tranny?
Old 12-23-2011, 01:12 PM   #1
Slayer8888 [OP] Slayer8888 is offline
Slayer8888 is on a distinguished road
Slayer8888's Tacoma Gallery
I just bought my TRD OFF ROAD last week, Awesome truck- I have a couple of issues/concerns, I have a slight ticking in the engine, sounds like a loose rocker, but since I don't think there is any rockers I don't know?? Is this normal for this engine? Also if I am driving in a lower gear and give it gas and let off and give it gas again I hear a 'clunk/clank' noise is this normal?
I just turned 800 miles on the truck, and have only owned used vehicles prior to this, and it is my thinking that these symptoms (noises) will only get worse in the future. Any ideas?
I plan on taking it back to the dealer, if not for a 'fix' at least to get the issues documented for future use. I do have the extended warrantee..
Old 12-23-2011, 01:13 PM   #2
Banned
Engine ticking is normal.
Sounds like you have some drivetrain slop. I'm not sure if this is normal on the 6 speeds.
Old 12-23-2011, 01:14 PM   #3
Lieutenant Dan.
DeeKay21's Avatar
Firefighter: Lieutenant
DeeKay21's Tacoma Gallery
The ticking noise is normal at idle in these trucks. Not sure about the ticking in low gear though but someone will chime in.
Old 12-23-2011, 01:19 PM   #4
Hey thanks FIREFIGHTER- its a Clunk in lower gears- loose tranny mount??
Old 12-23-2011, 01:21 PM   #5
wo ai ni bao bei ^_^
blackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shed
blackhawke88's Avatar
blackhawke88's Tacoma Gallery
clunking is most likely play in your U-Joints. My GF's U-Joint exploded at 30K miles after clunking when accelerating
Old 12-23-2011, 01:45 PM   #6
Shep6924 is on a distinguished road
Shep6924's Avatar
Shep6924's Tacoma Gallery
The taco tick...normal man. Also that clunking in the trany depending when it occurs is probably normal as well. Mine makes a clunking sound that I noticed immediately after buying mine, but I've since gotten used to it. The dealer said it was normal, just the way the trany is built. Either way I would go get it checked out. Also the computer memorizes your driving style and that could be parT of the clunking sound. It's getting used to your style. There's my two cents. Good luck.
Old 12-23-2011, 05:57 PM   #7
joes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shed
joes06tacoma's Tacoma Gallery
The tick is normal. This engine has solid lifters and will have some clearance in the valvetrain.
My truck has a significant amount of slop in the drivetrain. It has been that way since I got it at 40K miles and has not gotten any worse in the additional 20K I have put on it. The only other stick shift 4x4 I have owned did the same thing. An auto trans will cushion the shock and make it less noticeable I am sure.
You've got plenty of warranty time. I'd drive it and enjoy. If it gets worse take it in.
Old 12-27-2011, 12:12 PM   #8
Weou09 is on a distinguished road
Weou09's Tacoma Gallery
My 12 does tick but I don't have the clunk.
Old 01-04-2012, 10:49 PM   #9
Treaddirt is on a distinguished road
Treaddirt's Tacoma Gallery
Mine has the tick and the clunk. 2,500 miles on it already. Shortly after I purchased mine I was in the parts department and he parts department manager told me that the clunk sound was normal - he mentioned this to me without me asking because his wife had experianced the same thing on there recently purchased 2011 tacoma.
Old 01-05-2012, 12:05 AM   #10
Commanderwiggin is just really niceCommanderwiggin is just really niceCommanderwiggin is just really niceCommanderwiggin is just really niceCommanderwiggin is just really nice
Commanderwiggin's Tacoma Gallery
No Clunk here
Old 07-05-2012, 08:18 PM   #11
Got2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shedGot2ryde is one of the sharper tools in the shed
Got2ryde's Avatar
Got2ryde's Tacoma Gallery
Help! I've got 4000 miles(99% highway2wd) on my 12 Off Road with the 6spd and I'm getting quite a bit of clunking/chatter when I'm in 4wd going over uneven terrain(climbing in and out of some pond berms) and turning but not full lock turns. It's pretty loud and intense and doesn't sound natural. Sounds like it's coming from the cv joints. I know what a failing cv joint sounds like and it's a much "heavier" sound and slower than that. Anyone else experience this? I'm not looking forward to the hour drive each way to the dealership only to not be able to duplicate it in suburbia. I will try to post a video of it. Thanks!
Old 07-06-2012, 05:45 PM   #13
2009 Double Cab TRD 4x4
kshap448 is on a distinguished road
kshap448's Tacoma Gallery
I have a 2009 TRD Double Cab TRD 4x4 4.0 V6 and let me tell you the clucking noise has always driven me crazy. I have been back to the dealership time and time again to get this checked out before my warranty ran out. It is still doing it, and I have just about to get used to it, however it is a little annoying. I have changed U-Joints and still the clunk. What in the heck is it and where is it coming from? It cannot be good.
Old 11-12-2012, 05:15 PM   #14
Twalt87 is on a distinguished road
Twalt87's Tacoma Gallery
My 2012 tacoma 4.0l Ticks as well, when its hot at idle and when reving. Its annoying as hell, and im rather annoyed by it. It only has 600 Km on it. Has anyone found out any fixes or what it is yet? I heard the evap valve causes a tick, but that shouldnt go up and down with revs.
As for your clunking you hear, I would check the Steering intermediate shaft. I know a bunch of people have taken them in for that under warranty.
Old 12-06-2012, 12:52 PM   #15
Jarrid is on a distinguished road
Jarrid's Tacoma Gallery
Mine is more like a 'Tock' when I hear it from outside the driver side wheel well and more like a tick inside the cab after good engine warm up at idle up to around 1500rpm. maybe it's my old ears. I also hear some piston slap after a cold start then that goes away and I get the tick or tock. Piston slap on newer engines when warming up is very very common and usually a metallic raspy clanking sort of sound. I had a 3100malibu that sounded like the pistons were swapping cylinders.
Old 12-06-2012, 01:34 PM   #16
I believe the Tacoma tick , at least on the 2012 v6's is the VVT-I and perhaps some valve train noise from the tension-er and guides. believe me i was concerned about the noise until I found out about the Taco tick . I've only had mine for about A WEEK AND LESS THAN 600 MILES.
Old 12-11-2013, 08:11 AM   #18
m1a4shtf is on a distinguished road
m1a4shtf's Tacoma Gallery
I know this OP is old, but not too outdated-
The clunk is the driveshaft yoke slipping into place in the transmission. My 2012 4X4 auto Taco does it too. (Like my 2000 Ford F-150 did exactly) The splines get a little dry and the resistance binds and slips abit. I had read somewhere this is normal? I think not. My F-150 was remedied by greasing the the spline. I have not tried to fix the Tacoma yet as I'm still in warranty and the Dealership mechanics say the clicks and clunks are normal. I remind them each time i have the oil changed to document "normal" on the invoice so warranty has a record when normal breaks.
"Trust Me Luke"......."Use The Force"
Oh, yeah, mine ticks too,, but thats normal.....right?
Old 01-15-2014, 09:54 AM   #19
maykevin5 is on a distinguished road
maykevin5's Avatar
maykevin5's Tacoma Gallery
Just drive it till something breaks. Chances are it won't.
Old 01-15-2014, 05:35 PM   #20
tacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud oftacoma4 has much to be proud of
tacoma4's Tacoma Gallery
Can you explain this more? Are you talking about the slip yoke of the driveshaft or something inside the tranny? Shift fork, input/lay shaft,etc...
4wd clunking question?? mickyd9990 1st Gen. Tacomas 2 01-10-2012 06:10 PM
So...is 6spd to auto tranny possible? BRYLONATOR 2nd Gen. Tacomas 13 09-30-2011 09:38 PM
Tranny clunking when shifting into od stucksucksnayota 1st Gen. Tacomas 1 03-09-2011 06:26 PM
Clunking sound when shifting out of 4wd Enzo 2nd Gen. Tacomas 19 12-18-2010 06:51 AM
MY NEXT TRUCK: 6spd DC SB 4WD versus 5spd Auto DC LB 4WD 007Tacoma 2nd Gen. Tacomas 53 03-06-2008 11:18 AM
