Bad Door Lock Actuators?
Discussion in 'Technical Chat' started by Blake, Jan 15, 2012.
  1. Jan 31, 2015 at 10:20 PM
    #101
    jandrews
    '09 FourDubDee TRD OR
    Mine has been out for over a year and I'm too lazy to do anything about it. The fob and key both still work, and so do the electronic controls, the only thing is the little indicator on the inside of the door does not flip at all.
    I can still move the indicator by hand, but it does not affect whether the door is locked or not. The lock must be controlled by fob, key, door lock button.
    I'll fuck with it if it ever gets worse. As it stands, I really don't care that the little indicator doesn't react.
  2. Feb 1, 2015 at 9:32 AM
    #102
    Renreb
    Renreb New Member
    Todd
    Margate, FL
    08 PreRunner
    When the remote entry works, my door will unlock. The manual lock works from the inside as well. I just cannot unlock or lock my door now with the key. The key worked prior to me removing the locking mechanism.
    Any ideas as to what I was doing wrong in trying to get the halves separated?
  3. Feb 7, 2015 at 12:19 PM
    #103
    Renreb
    Renreb New Member
    Todd
    Margate, FL
    08 PreRunner
    I went back through the procedure and I was able to get the two halves apart and fix the problem of my key not working. Thanks for these walk-throughs, they really helped me.
    Now I can fix my brothers and my friends sons' trucks.
  4. Feb 7, 2015 at 2:16 PM
    #104
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Why wasn't the key working?
  5. Feb 11, 2015 at 7:58 AM
    #105
    Renreb
    Renreb New Member
    Todd
    Margate, FL
    08 PreRunner
    I wasn't aware of the "stem" that comes off of the key hole that has to insert into a groove on the locking mechanism. It was an easy fix once I saw what needed to be done.
    I think the first time that I tried to fix it, I had a little too much to drink, which caused "drunken errors" to occur.
    Sober me fixed everything pretty easily.
  6. Mar 31, 2015 at 5:49 AM
    #106
    jjew18
    jjew18 the Nightman cometh!
    John
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Okay, got mine done last night, we'll see how long it stays. I couldn't get the damn motor apart to clean the posts. So I figured, I can't hurt anything so I sprayed a very small amount of break cleaner in the openings of the plastic end, then used compressed air to blow dry it. (I figured worst that could happen is it still doesn't work, or blow shit up which would be kind of cool)
    I took a few pics of the steps that I'll do a small right up on, but most importantly I wanted to post a pic of the actuator just in case you do what I did. Mine fell apart and I took a while to figure out the way it goes together since none of the pics I saw on here were of our actual actuator (at least not the rear drivers side).
    I'll update in a few months to see how well it holds up; I know a lot of you report it works for a bit.
  7. Apr 4, 2015 at 10:24 AM
    #107
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Please post pics. I have both my rears out and will try to fix within the next week. Thanks!
  8. Apr 5, 2015 at 1:28 PM
    #108
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    So if you've got them out. I still haven't done a full write up but here is a quick and dirty (of just the actuators):
    I used break cleaner, I know another person on here used electrical parts cleaner. When spraying, I did the smallest spray/burst I could possibly do. Then in the same openings I sprayed a can of compressed air.
    Reassemble.
    Let me know if you have any questions, good luck.
    05Taco4x4 and Crom like this.
  9. Apr 5, 2015 at 1:30 PM
    #109
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    Crap, I just saw all of my wonderful text is too small. Son of a bitch. If you can't blow them up, let me know and I can re-write or explain what they say.
  10. Apr 5, 2015 at 6:09 PM
    #110
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    That should help a lot. Thank you!! I'll probably attempt both my rear doors next weekend.
  11. Apr 6, 2015 at 6:01 AM
    #111
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    Sounds good, let me know if you have any questions. I'll try to get the pics blown up so the text is bigger and readable.
  12. May 9, 2015 at 12:04 AM
    #112
    Akirakodi
    Akirakodi Member
    '08 Super White DCSB 4x4
    I did this and got the motor working again, but rushed and forgot to verify the linkage working properly before shutting the door. Now the door lock functions but the latch doesn't and the door is completely stuck. It won't open from the inside or out. I'm thinking I'll have to drill the assembly and break it apart from inside until the latch releases. Anyone else make this mistake? Don't rush this job, check and double check before you shut that door. Any advice on how to get the door open is appreciated.
  13. May 16, 2015 at 4:25 PM
    #113
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    Yikes! I'll take a look at mine and see if I can see anyway this can be done. Right off hand can you remove the handle/lever and reach in through there?
  14. May 17, 2015 at 7:40 PM
    #114
    Akirakodi
    Akirakodi Member
    Hey, thanks for the reply. I got the door open by drilling out the box from the inside. It was a royal pain but eventually I hit the right spot to release the latch!
  15. May 19, 2015 at 3:54 PM
    #115
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    I was looking and I didn't see many damage free options, except something like what you did. Hope the hole isn't too big. Glad you got it.
  16. May 19, 2015 at 7:12 PM
    #116
    Akirakodi
    Akirakodi Member
    Thanks. No hole at all, since I had door panel off already. Just stuck a drill in from the inside and drilled out the box. No damage to the truck at all, just had to buy one actuator box. Fixed the other doors myself, taking my time not to make the same mistake!
  17. May 26, 2015 at 11:56 AM
    #117
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    OH, gotcha, I thought this was after you had put the panel on. In that case, I did do that too. I don't remember how I got it undone, but no drilling involved. Glad you got it either way.
  18. May 26, 2015 at 12:00 PM
    #118
    jjew18
    John
    Alliance Airport
    05 PreRunner SR5
    If I'm understanding the problem correctly, this is a very easy fix, 2 minutes after you get the door panel off. The cable for the switch came out of the actuator.
    Crom likes this.
  19. Jun 12, 2015 at 6:46 AM
    #119
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just so you know, the same company that makes Brakleen also makes an electrical cleaning product. Same red can but is specifically meant for cleaning electrical components. It seems to work pretty well in my experience.
    I did that also but, fortunately, I was able to reach in and cycle the actuator by hand. Sucks you had to drill yours to get it to release.
  20. Sep 11, 2015 at 5:28 PM
    #120
    cjcarner
    cjcarner Well-Known Member
    Colin
    Savannah, GA
    2011 TRD Sport 6MT DCSB
    Rhino Rack roof rack with an Inno fairing, Snugtop Rebel cap
    Coolerman and Boston10Taco like this.
