#1 |
05 and up Transmission servicing
I would like to know if anyone has done a flush and service on their transmission before the rcommended 100,000 mi service.
#2 |
Mom says I'm special!
Why would you need to?
#3 |
Yes, I had it done at 1,500 miles to get rid of the metal shaving in the transmission. And yes, there were shavings in there just like any other auto transmission when you first break it in.
The Service Manager and mechanic could not understand why I wanted it done since the transmission oil is good for 100,000 miles, but as I explained to them, "No matter how much electronic stuff they put into new vehicles, it's still mechanical undernether all of it and that means a break-in period". As a result, when they dropped the pan, there was metal shavings stuck to all 5 magnets inside of the auto transmission pan that they had to clean off before bolting the pan back on and filling up again. |
#4 |
I live inTucson, the driving and traffic sucks! a lot of stop and go. I started thinking about it because the drive train warranty will be long gone before 100,000. who is going to pay for it then? ME! so i have talked to a lot friends with tundras and tacomas. All changed it starting at 30,000 intervals. The problem on the 05 and up, is that you MUST use the toyota fluid. just a drain and refill at the dealer is around $148.00 AAMCO will do a filter and complete flush for $115.00
#5 |
There is more than just using the Toyota transmission fluid. It is also a rather complicated method of refilling the auto transmission. It required that the transmission be at a certain temperature before they completely fill it and then have to run through the gears several times to completely reach the "full" mark. And all this was done while being hooked up to there diagosnic machine.
| Display Modes | |
| 6 speed transmission | BrianPK | 1st Gen. Tacomas | 2 | 11-21-2007 07:35 PM |
| Auto Transmission Usage | Spacedude | Technical Chat | 1 | 09-18-2007 01:26 PM |
| AT Transmission Filter Kit | agapedisciple | Technical Chat | 3 | 09-18-2007 01:10 PM |
| Transmission Cooler Options | missingthenw2001 | 1st Gen. Tacomas | 3 | 04-21-2007 01:08 PM |
| 05 transmission question | scott c | 2nd Gen. Tacomas | 6 | 12-12-2006 04:30 AM |
