gearing and gen questios
Discussion in 'Technical Chat' started by Karma Coma, Oct 2, 2012.
  1. Oct 2, 2012 at 6:06 AM
    Karma Coma
    Karma Coma [OP] Active Member
    tacoma sr5.3.4 v-6
    six inch fabtech lift, 315-75-16 tires,
    just got an o1 tacoma. first is this a first or second gen, how does that work. what years. second. the truck was decked out when I got it, 35 inch tires and 6" db lift. but I dont think the gearing was ever changed. how would I know. is there a way I can count the rotations in nutrual to get the gear ratios?
    and if it were stock 4.10, Im torn with 4.88/5.13. its an automatic, and Im gonna go down to 285/75/16 in a couple weeks., any one know what the rpms in overdrive would be at 65 with either of these? thanks!!
  2. Oct 2, 2012 at 8:17 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    1995 was first year for the Tacoma. Sometimes called 1995.5 as it came out mid year. First gens also had changes in body/interior during the run. Your 2001 is a First gen.
    Here is the sites tyre calc. Shows you the difference when changing tyre size, effect on speedo and gives RPM at 65 with various gear ratios.
    http://www.tacomaworld.com/forum/tirecalc.php
  3. Oct 2, 2012 at 8:27 AM
    Hillingdoner
    Rio Rancho, NM
  4. Oct 2, 2012 at 6:55 PM
    Karma Coma
    tacoma sr5.3.4 v-6
    what I dont under stand is....is the other wheel moving too?..... I race RC short course trucks, and they have genuine spider gear diffs. but if only one wheel is spinning the the wheel would be moving twice as fast.....correct? so do I I lock up the other wheel? does it spin too?
  5. Oct 2, 2012 at 8:40 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    no, rotation is constant, jack up the rear axle, mark the tire at six o`clock and the drvshft six o`clock,,, turn tire one revolution and count how many times the drvshft goes around, it will give you a good idea what the gear ratio is.
    ie: 3 3/4 shaft rev's should be 3.73, 4 and a little is 4.10, 4 and a half is 4.56
    get the jist??
  6. Oct 2, 2012 at 9:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've been considering gear change options too. It is an oft discussed topic in the 1st gen section. 4.56 vs. 4.88s.
    In a 1st gen auto, with 31" tires going 60 mph the rpms on overdrive are ~1900, the rpms in 3rd gear are ~2800
    Based on some calculators I've used, with 33s going 60 mph:
    4.10 4.56 4.88
    1750 1950 2100 overdrive
    2600 2900 3150 3rd gear
    If these numbers are accurate, it looks like 4.56s are closer to stock ratios and might be better with 33s.
  7. Oct 3, 2012 at 12:53 PM
    Karma Coma
    tacoma sr5.3.4 v-6
    i did exactly that, and I got a little over two revs on the drive shaft........that dont seem right...even if it wer a stock 3.91. which is what the door sticker says
  8. Oct 3, 2012 at 5:25 PM
    Karma Coma
    tacoma sr5.3.4 v-6
    ok so it looks like .I got a 4.11,,,,,,after spinning both wheels,. but this is weird.....why would the pumpkin get hot after being on the interstate for 20 min? almost to hot to touch
  9. Oct 4, 2012 at 5:47 AM
    shemp
    shemp Well-Known Member
    They do get quite warm, especially when you have too large of wheels for the gear ratio, it means you're running with a higher torque on the driveshaft in order to sustain speed.
    How about changing the fluid to a nice high quality synthetic? That should knock a few degrees off. Don't take it apart just to inspect it, better to look at the fluid first. If there are chunks of gear in the fluid, THEN you can start thinking about taking it apart to inspect.
    Regarding spinning one vs both wheels: 4.11 turns of the input shaft = ONE turn of the ENTIRE output shaft (both wheels). If one wheel is held stationary, all of its revolutions will be transferred to the other side, so it will turn twice as much. Think of it as two turns of one half shaft = 1 turn of the full shaft.
