Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jun 21, 2013 at 5:57 AM
    #1341
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The manual states that over filling the diff, can cause the oil to "froth" or foam up, thus causing the gears to over heat.
  2. Jun 21, 2013 at 6:15 AM
    #1342
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Good info. Thanks Chris.
  3. Jun 21, 2013 at 6:28 AM
    #1343
    DheadTaco
    DheadTaco Pill it till you kill it!
    Gulf Coast, Mississippi
    07 Tacoma PreRunner SR5 Impulse Red Pearl
    -Color Matched Grill & Toyota emblem -Headlights from WOTM -Tinted Fogs with Lamin-x (Tint) -Tinted taillights with Lamin-x (Tint) -6K HIDs in headlights and fogs -20% tint all around -Plasti-dipped badges -Plasti-dipped back bumper -Mud flap mod -'10 running-boards -LEDs all around -AFE drop-in
    Now you can begin to refill your differential! You should add your LSD additive sometime between your first and second quart of gear oil.
    If I have a 2WD PreRunner do I still need to add this additive?
    When filling, the oil will begin to run out at some point. Put the plug in the fill hole, and let the gear oil run down into the lenght of the axle shaft. After a few minutes, remove the plug and begin to fill again.
    What is the quantity of oil that it call for to put in?
  4. Jun 21, 2013 at 6:28 AM
    #1344
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Was your truck on level ground?
    If you were parked with the nose pointing downhill - your essentially over filling it.
  5. Jun 21, 2013 at 6:30 AM
    #1345
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only if you have a mechanical LS Diff, as indicated by the sticker on the axel, as in the pic in the first post.
    and it takes 3 quarts.
  6. Jun 21, 2013 at 6:30 AM
    #1346
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Did you take into account the amount left in each quart. I use a pump and have about a quarter quart left in each jug so there for it wilm take 4 quarts to get 3.12qt's.
  7. Jun 21, 2013 at 7:02 AM
    #1347
    Janster
    Jandy
    Lancaster, PA
    FOR Mechanical LSD only
    It's been several days....but I had to add 1/2 bottle of friction modifier to prevent the diff from rumbling for a total of 1.5 bottles.
    Even though Mobile 1 says they put friction modifier in the 75W-90....it's not much - if any at all.
  8. Jun 21, 2013 at 7:07 AM
    #1348
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Is adding the friction modifier typical? I am about to change mine, so should I just add the fric modifier to the bottles as I am filling up the diff?
  9. Jun 21, 2013 at 7:11 AM
    #1349
    Janster
    Jandy
    Lancaster, PA
    I'm pretty certain...you do not have a mechanical LSD. I think they stopped after 2008 model year.
    The only time you need friction modifier is if you have the mechanical LSD.
  10. Jun 21, 2013 at 7:12 AM
    #1350
    TACO TX
    Kelly
    Denison ,Texas
    Mobile 1 says LS compatible, not that it has friction modifier in it. You still have to add modifier to it. 2009 and up do not require LSD additive.
  11. Jun 21, 2013 at 7:14 AM
    #1351
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    janster pointed out that there is another Modil 1 Gear oil that says the addative in in the bottle.
  12. Jun 21, 2013 at 7:23 AM
    #1352
    Janster
    Jandy
    Lancaster, PA
    Some of the bottles actually say "Friction Modifier Included".
    When I tried to get bottles without the 'Friction Modifier Included' - the sales guy tells me... "It's all the same part number".
  13. Jun 21, 2013 at 7:50 AM
    #1353
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Ah, thanks for the clarification. Almost had a wrench thrown in my plans.
    So LSD Additive = friction modifier?
  14. Jun 21, 2013 at 11:12 AM
    #1354
    Janster
    Jandy
    Lancaster, PA
    I wouldn't assume anything - it depends on the manufacturer. 'Additive' can mean many things to different people/companies.
    You can still use the LS oils (with or without the friction modifier) in your Open or Locked (non mechanical LSD) differentials.
  15. Jun 21, 2013 at 11:16 AM
    #1355
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You don't have the mechanical LSD so no need for the friction modifier/LSD additive. None of the TRD Off Roads have a mechanical LSD.
  16. Jun 21, 2013 at 3:55 PM
    #1356
    quantum
    quantum Well-Known Member
    FYI, I was just at the stealership to get the gaskets and LSD additive and they said that Toyota recommends their additive or the GM one. Here is what I picked up:
  17. Jun 23, 2013 at 4:52 PM
    #1357
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Nice write-up, makes me feel confident enough to do this myself when I change my oil in 800 miles.
    Just to be clear, I have a 2008 TRD OR, so I'm guessing I need the LSD additive, right? And is there only one type of gear oil? For example, synthetic vs non-synthetic?
  18. Jun 23, 2013 at 5:08 PM
    #1358
    TACO TX
    Kelly
    Denison ,Texas
    No you dont need LSD additive, you have a locker and i would use Mobil 1 synthetic in 75-90. May as well do front diff and transfer case also, they are just like the rear. Same concept.
  19. Jun 23, 2013 at 5:11 PM
    #1359
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    "(for you guy like me w/ the Sport model, you'll need a 4oz. tube of LSD additive)." from the very first post in the thread. ONly the sport's need the additive.
  20. Jun 23, 2013 at 5:21 PM
    #1360
    TACO TX
    Kelly
    Denison ,Texas
    ^^^^^WUT!^^^^^ If you have a OR with a locker you do not need LSD additive. Thats some complicated shit you just wrote right there!
