SecretSquirrel's 2005 Tacoma w/ All-Pro Bumper, Satoshi Grille, Cooper 305 STTs & more...
Changing differential fluid - A step by step "HOW TO"
Old 06-04-2009, 08:34 PM   #161
Slap Chop
chris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond repute
chris4x4's Avatar
chris4x4's Tacoma Gallery
Originally Posted by brianr View Post
Sean, why not just put some penetrating oil on the bolt, and find a nice pipe for some extra leverage on your ratchet?
To add, many times tapping the wrench with a hammer will loosen the bolt. Tapps...not a Gorilla blow.
__________________
a computer once beat me at chess but it was no match for me at kick boxing.
space for rent
Old 06-04-2009, 09:22 PM   #162
barge it
brianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond reputebrianr has a reputation beyond repute
brianr's Avatar
brianr's Tacoma Gallery
indeed my friend.
__________________
Kennett Brewfest
Old 06-04-2009, 09:49 PM   #163
EverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud ofEverTaco23 has much to be proud of
EverTaco23's Avatar
EverTaco23's Tacoma Gallery
Good news!!! I just did my diff. and t-case. about a week or so ago, and I just did a mpg check, and Im up to 17. Yippy!!!
Now to see what some TRD headers give me....
Old 06-04-2009, 09:50 PM   #164
barge it
brianr's Avatar
right on!
__________________
Kennett Brewfest
Old 06-07-2009, 11:02 AM   #167
ellocodetroit is on a distinguished road
ellocodetroit's Tacoma Gallery
Thanks for the write up guys. The Taco is my first truck and I did not know I had to change the diff fluid. It took me awhile to figure out I only had to change the rear. I have a prerunner so no worries about the front and trancase.
I used RP gear oil and the Taco feels like it rolls smoother from a stop.
I have 36,100 miles on my Taco and the diff fluid did not look that dirty. The hardest part was removing the plugs. I had to used a pipe wrench to hit my ratchet to loosening the plugs.
I left my drain pan inside the garage yesterday and this morning the garage stunk like diff fluid. I won't be doing that again.
Thanks again guys.
Old 06-07-2009, 11:33 AM   #168
My 2 kids
luk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond reputeluk8272 has a reputation beyond repute
luk8272's Avatar
luk8272's Tacoma Gallery
My rear fluid looked brand new to the point where I wasn't sure if I should change the front but I did anyway and damn thank god I did. The front was a dark grey and had some water in it. Haven't done the T-case yet because they didn't have enough oil for it. I could do the rear diff. and either the front diff or Tcase.
__________________
Arkansas Superlift Park 4/10/09
Big Easley Run 5/17/09
Windrock Coal Creek OHV 6/20/09
Old 06-07-2009, 09:59 PM   #169
PT6 PT6 is offline
Who's flyin this M#$*&! outa here?
PT6 has a spectacular aura aboutPT6 has a spectacular aura about
PT6's Tacoma Gallery
Now I am confused. I saw it somewhere in this thread that the TRD Off Road did not come with a limited slip diferential. I got my window sticker out and mine says that I have an auto lsd. I also have the option of locking it via a button in the cab when needed. I thought they all came with the lsd? Do I need the additive ( I believe that I do)? I am nowhere near 15K yet, just curious. Thanks.
Old 06-08-2009, 07:02 AM   #170
My 2 kids
luk8272's Avatar
My advice would be to go look at your rear diff and on it it will say LSD if this is so you will need the additive. But seeing you have the locker you shouldn't need the additive.
__________________
Old 06-08-2009, 05:52 PM   #171
Slap Chop
chris4x4's Avatar
The Auto LSD uses the brakes to modulate wheels spin, so no LS Diff addative is required.
__________________
space for rent
Old 06-08-2009, 06:29 PM   #172
PT6 PT6 is offline
Thank you. I actually looked at your photos again and clearly saw the sticker. I climbed under mine and it did not have one.
I noticed in my manual that the 09 calls for 75W85 in the front and rear difs, but 75w90 in the transfer case. Anybody just running the 90 in all three? It would simplify things as I only saw the 90 at the parts store.
Would something this trivial void my waranty? (probably know the answer to that one).
Old 06-11-2009, 06:50 AM   #173
Coheednme13 will become famous soon enough
Coheednme13's Tacoma Gallery
ok so I've been reading through this and since I'm approaching 30K I'm wondering if I need to do anything different since I have an automatic reg cab. No 4x4 or anything crazy. Do I need the same fluid and process to change it?
Also, I live on a dirt road and I was wondering if anyone had done a write up on maintaing your suspension. I would like to know what I need to grease and tighten or check. Also, do I need to grease my drive shaft and if so can anyone recommend how to do this. I don't know a lot about maintaining my vehicle other than chaning oil and plugs.
__________________
Pics of my ongoing audio install check them out
Old 06-11-2009, 07:11 AM   #174
kyle32963 is on a distinguished road
kyle32963's Tacoma Gallery
so if u never done it dont?? i got mine at 52k and i have 95k on it now
Old 06-11-2009, 07:13 AM   #175
Slap Chop
chris4x4's Avatar
Nothing to maint. on the suspesion....Just keep it clean. For the diff, the procedure is the same, but you dont need the addative.
You should ALWAYS service your vehicle propperly, and at the recomended milage.
__________________
space for rent
Old 06-18-2009, 07:52 AM   #176
Blaise22 is on a distinguished road
Blaise22's Tacoma Gallery
When you change your oil are you going with synthetic?
Royal Purple dosnt even make 75W85 gear oil so it looks like im going with either the 75W90 or a different brand.
Old 06-18-2009, 09:52 AM   #177
PT6 PT6 is offline
Yes, Mobil 1.
Old 06-18-2009, 08:24 PM   #178
hokiemule is on a distinguished road
Gender: Chick
hokiemule's Tacoma Gallery
I saw one post about this, but no follow-up: has anyone used Redline MT-90 in these trucks and if so, what were the results? It's a GL4, 75W90. I put it in my MR2 Spyder's tranny, and I'm very impressed with it; however, my Spyder doesn't have a LSD.
I don't have any personal experience with Royal Purple products, but I've heard some bad things about them. Shear was the most consistent complaint about their products.
Old 06-19-2009, 10:28 AM   #179
I have a trd offroad that does not need the additive, Is the redline oil listed below the correct one or should I get the 75W90 above it?
http://www.redlineoil.com/products_g...5&categoryID=6
Old 06-19-2009, 10:29 AM   #180
Slap Chop
chris4x4's Avatar
It should work just fine.
__________________
space for rent
Home > Tacoma Garage > Technical Chat
Display Modes
differential fluid Keason1* 2nd Gen. Tacomas 2 09-16-2008 01:55 PM
step bars mattioss 2nd Gen. Tacomas 6 08-31-2008 07:53 PM
step tubes. montgomery_30824 2nd Gen. Tacomas 19 08-17-2008 03:51 PM
step bars Marioso 2nd Gen. Tacomas 2 06-28-2008 04:59 AM
Step tubes Sodbuster 2nd Gen. Tacomas 11 04-06-2008 06:03 PM
Copyright © 2009 Tacoma Forum
