Who has had a major failure with the 1GRFE V-6??
Old 09-09-2013, 10:32 AM   #21
rcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shed
rcfreak201's Tacoma Gallery
Sub'd. I'll be adding to this thread soon
http://youtu.be/a52ZHD3cF3g
Old 09-09-2013, 10:41 AM   #22
XXXX [OP] XXXX is offline
Banned
XXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shed
XXXX's Tacoma Gallery
Originally Posted by BlueT View Post
Problem is none of those failures are really "Toyota" failures. I have yet to see something wrong with those engines. So far all failures had been due to improper maintenance, (Sludge, poured something funky to engine, bad air filter, water ingestion etc)
Forgot you posted this.
So the bad oil pumps and bad bearings don't count? It is well known the early models had issues with their oil pumps and bearings.
I'm not one of the early models. Just wondering where you got your info from if you never heard of these issues.
Old 09-09-2013, 12:11 PM   #23
Tor-nication
Torspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shed
Torspd's Tacoma Gallery
Low oil, or poor oil circulation is the death of a healthy engine.
The last rebuild of my spare engine was due to poor circulation. Had plenty of good oil, but the previous owner clearly refused to change their oil. As a fail on my behalf, I never pulled the lower oil pan before install. But once the damage was done, I had to. The sump was so clogged of burnt oil, that it only had to clogged-free spots that were about the size of the tip of the pinky finger. I was surprised that it ran the few months that it did.
Old 09-10-2013, 10:46 AM   #24
BlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shed
BlueT's Avatar
BlueT's Tacoma Gallery
Ok I may have missed that "well known" but do you have a link to anybody losing engine due to bad oil pump or bearing (which exact bearing we talking about)?
I can tell you that if anybody mentions "bad oil pump" on 1GR I immediately sense BS.
There are only two moving parts in that thing, and they are not even delicate. The fact is, oil pump will always pump oil ....unless:
1 Stops turning because crankshaft is not turning or crankshaft bolt is loose.
2. Oil can not be sucked from Oil pan.
The only "known" 1GR trouble is head-gasket on early trucks. And even that could be avoided if you warm your truck before driving.
Old 09-10-2013, 02:33 PM   #25
Because 4R
Wishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shed
Wishbone Runner's Avatar
Wishbone Runner's Tacoma Gallery
Damn, that does not sound good!
Any idea on the cause?
Old 09-10-2013, 02:41 PM   #26
A_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shedA_Ninja_Racer is one of the sharper tools in the shed
A_Ninja_Racer's Avatar
Army: Medicaly Discharged 13M
A_Ninja_Racer's Tacoma Gallery
when you guys say these issues were common on earlier made trucks what years were you referring to?
Old 09-10-2013, 02:54 PM   #27
MGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shed
MGMTacolover55's Avatar
MGMTacolover55's Tacoma Gallery
OK the pistons move so do the valves and pretty much everything the headgaskets move
Old 09-10-2013, 04:50 PM   #28
Banned
I have no idea why you are asking me? You post in every single engine thread and I'm sure if I took the time to read the ones below you posted in them I looked into the issues these engines have a year ago and no I didn't save links. Here are the three that popped up on a simple single search in here and no I did not read them all because I don't care until I know for a fact whats wrong with mine.
http://www.tacomaworld.com/forum/2nd...t-so-good.html
http://www.tacomaworld.com/forum/2nd...ml#post1384704
http://www.tacomaworld.com/forum/2nd...ml#post5480839
Bad oil "flow" - sorry for the misrepresentation/bad terminology.
You ask me for proof but you provide no proof. You state "none of those failures are really "Toyota" failures" and you have zero proof to go on. Just because you haven't seen it doesn't mean they don't exist. Not sure why I'm the one needing to provide proof when your the one calling me out
Here's one for you:
Originally Posted by jcraig49 View Post
I just got the final word from Toyota. They have no idea what caused the bearing failure because the oil wasn't sludged so they agreed to cover it. Rock on Toyota and thanks for all the replies.
Rod bearing from 2009
You can search for more if you want Ill find my answers when the old one gets torn down so like I said I don't really care - I just started this thread for people with engine issues. If you want to flame the reasons there are issues you can have your fun. The thread title is not "Who has had a major manufacturers defect with a 1GFRE V-6"
The sky is falling!!!!!
Old 09-10-2013, 05:05 PM   #29
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
I think BlueT's point was that oil pumps are so simple and reliable that there are very few things that CAN go wrong. So if you have an oil delivery issue it's not likely to be the pump. Sounds to me from reading those threads that's the case and it's more of sludgy engine oil.
boyd's engine problem almost sounds more like broken rings to me
Old 09-10-2013, 05:19 PM   #30
Banned
I'm hoping for valve issues
And if it is that, everyone can laugh while I kick myself in the ass for the next 20 years for not fixing a much easier issue. Either way I got a complete engine for a killer deal so I can strip it and sell it if need be.
I got 1k on the oil I put in there last year when I first noticed I had a gremlin in there with a hammer. Wonder if it's even worth sending it in for analysis?
Old 09-10-2013, 09:59 PM   #31
leak down test, stat!
Old 09-10-2013, 10:21 PM   #32
BlueT's Avatar
Here's one for you:
You missed previous quote from that person...
I have officially been denied warranty service because Toyota says the oil wasn't changed enough or run low on oil which caused excessive rod bearing wear. Lesson learned here, if you buy a Toyota (or any vehicle) with a warranty get and keep oil change receipts from the shop you get the oil changed at or have it done at the dealer. My 2006 Toyota Tacoma has officially lasted me 3 months and 3,000 miles before needing an engine overhaul. Nice move Craig
How do you cause rod bearing failure? Answer: By starving engine of oil. (maintenance)
how it was starved nobody knows and will not know since vehicle was bought used. I sold my VW to dealership after running three times with out oil because oil line to turbo had burst. I am pretty sure if they resold it, somebody had lost engine very shortly after.
That was your first link.
Second Link:
Originally Posted by lucky View Post
Does this view indicate extended periods of unfiltered oil passing by, or was this a hot spot...
notice black streaks where you pour oil into engine. This engine most likely failed because somebody had poured something other than oil. Thats also the side where components had failed. Again, somebody pouring something other than oil into engine is maintenance failure.
And Link # 3 with massive sludge build up pictures of engine that failed.
Originally Posted by ggms16 View Post
Hi Guys...
I have a bunch of updates and a few pictures to share.
First of all. I will to eat my own words against toyota as a gentleman.
The engine died because of SEVERE sludge. Yes, I did all the services at the dealer, but the truck is mine since 50k miles, I don't know what happened before that 50k. Or I don't know if the dealer was using cheap oil instead of a good one.
The truth is that the oil channels were covered in sludge, so did part of the oil pump. That says enough and you all will understand what happened here.
Pictures of the old engine:
Attachment 165165
Attachment 165166
Attachment 165167
Attachment 165168
Attachment 165169
Attachment 165170
Attachment 165171
Attachment 165172
Ok. I don't have enough evidence to point the dealer, even if they used non original filter, this kind of sludge is definitely an oil-maintenance related issue.
Again bad maintenance. I have yet to see something that failed due to design in those engines (apart from head gasket) so far all I see is bad maintenance.
Now if you say headgasket on early models is subpar, than you have a case. Thats the only item so far that had been indentified to have flaw.
Now proper title than would be "Who had f..ed his engine?"
Old 09-10-2013, 10:32 PM   #33
BlueT's Avatar
It was 05-06 mid year I believe. 07+ should be good.
Old 09-11-2013, 06:12 AM   #34
Tor-nication
Second Link:
Toyota recently changed their crank bearing design. The bearings now, are narrower than earlier years. Don't know when the change was implemented, but I compared it this year '13, to my '06 bearings.
Add to that a light weight oil, such as a 20 weight, and it is just a matter of time before the oil gets to hot, liquefies, and bearing contact happens. Especially considering the low ZDDP content that US SAE Branded oils have to have. Recipe for disaster. For the 1GR and all other types of engines.
If someone uses a 5w-20 oil, change it to something thicker. Otherwise, enjoy an short service life of your engine.
Also, "Gas Saving" on the oil cap, is there specifically for that. Not for longevity.
Old 09-11-2013, 10:26 AM   #35
Skinkwerks Rockware & Fabrication!!
BradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shedBradyT88 is one of the sharper tools in the shed
BradyT88's Avatar
Army: Cannon Crew Member
BradyT88's Tacoma Gallery
Would recommend not running thinner oils at all? My wife has an 08 Mazda 3i with the little 2.0L in it and it says to use 0W-20...
Old 09-11-2013, 10:33 AM   #36
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
x2, my wife's car takes 0W-20, I've been using 5W-20 so far.
Old 09-11-2013, 10:40 AM   #37
Tor-nication
Nope. I would not recommend running a 20 weight at all. Doesnt matter what winter modifier (ex. "5w") is in there. If you do, don't do extended drain intervals with it. It is already being taxed enough as is.
Especially wouldn't use recycled 20 weight.
Again. All that a 20 weight is for, is for gas mileage. Not for protection, durability, and longevity.
Old 09-11-2013, 10:46 AM   #38
BradyT88's Avatar
Good to know! Thanks! What do you recommend running? 5W or 10W and 30 or 40. I've been running 5W-30 in both my car and Taco.
Old 09-11-2013, 10:55 AM   #39
Running For Mayor of TW
richardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shedrichardbui23 is one of the sharper tools in the shed
richardbui23's Avatar
richardbui23's Tacoma Gallery
what about 0w-30?
Old 09-11-2013, 11:06 AM   #40
BradyT88's Avatar
Originally Posted by richardbui23 View Post
what about 0w-30?
I didn't know there was such a thing. haha. Although I didn't know 0w-20 existed either until I changed the oil in my wife's car.
1GRFE Engine Swap lucky 2nd Gen. Tacomas 43 01-24-2014 09:39 PM
1grfe internals jayridinfast 2nd Gen. Tacomas 7 05-23-2012 05:12 AM
1grfe harness and parts wallasx 2nd Gen Tacoma Marketplace 3 04-19-2012 07:29 AM
i hate the 1GRFE Detective_Dan General Automotive 22 06-21-2011 07:18 PM
