P0402 code, how urgent?
Old 12-22-2012, 10:06 AM   #1
abledsoe [OP] abledsoe is offline
abledsoe is on a distinguished road
abledsoe's Tacoma Gallery
My Tacoma:
1999 PreRunner 2.4L auto, 157K miles.
A couple of weeks ago the CEL came on. The truck seemed to be running as normal but I went ahead and took it to my mechanic (not a toyota dealer). He said it gave an EGR code so they checked the system and found nothing wrong, suspected a stuck valve. They cleaned it and reset the CEL. A couple of days later the light came back on, still seemed to be running just fine.
I borrowed a diagnostic scanner and got code "P0402" suggesting the same thing.
Im not much of a mechanic at all so fixing it myself is probably out of the question. How urgent is it that I get this fixed? Can it wait about a month? Like I said, it seems to be running just fine, no loss of power or anything. I don't put very many miles on this beast but I do really want it to last another few years.
Any thoughts? Thanks so much
Old 12-30-2012, 12:09 PM   #2
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
P0402 is for excessive EGR flow detected. This is an emissions related code. If there actually IS too much flow it can cause excessive emissions and possible stumbling and hesitation. Can it wait a month? Possibly. It is hard to tell because we don't know if the fault is a true failure, or a sensor problem. If it is a sensor problem, then you could wait, if it is a failure, then it may get worse.
Urgent help! P0302 code Bamahoyt 1st Gen. Tacomas 10 12-09-2012 03:01 AM
Need some help Code P0402 Tacito 1st Gen. Tacomas 16 08-18-2012 06:21 AM
Truck Bogging down when Cold - P0402 Code - Ideas? Sixgun 1st Gen. Tacomas 1 06-06-2012 08:18 PM
P0402 code Kelly Girl 1st Gen. Tacomas 10 05-12-2012 02:22 PM
Exhaust Manifold leak vs P0402 code HELP dustinclm Technical Chat 3 02-10-2011 09:09 PM
