CB Quick Disconnect, how?
Old 01-10-2013, 10:44 AM   #1
STRIKER TRD
akaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shed
akaryanreynolds's Avatar
akaryanreynolds's Tacoma Gallery
Thew a quick disconnect on my firestik yesterday and was wondering if anyone has put them above the spring before if not why? or whats the logic behind installing it below the spring?
I have it like this right now, figured that this way would save the spring from being stolen when I take off the antenna.
Old 01-10-2013, 12:50 PM   #2
mmm Tacos
Swordknives is a glorious beacon of lightSwordknives is a glorious beacon of lightSwordknives is a glorious beacon of lightSwordknives is a glorious beacon of lightSwordknives is a glorious beacon of lightSwordknives is a glorious beacon of light
Swordknives's Avatar
Swordknives's Tacoma Gallery
I like it the way you have it. if you put it above the spring someone could steal it. also putting it above the spring would look funny with out an antenna.
Old 01-10-2013, 01:07 PM   #3
Banned
XXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shed
XXXX's Tacoma Gallery
I ran one for a while. I found that it hurt my reception. It also rusted out and became a POS. I removed it and moved my mount down lower. The less hardware you have the signal going through the better.
No matter what you can steal the antenna. The only difference is one way you can steel the spring and the other way you can't.
Old 01-10-2013, 02:19 PM   #4
STRIKER TRD
Yah I was worried about reception so I bought an SWR meter going to test it out right now with the QD and see how it works for the next month along with the weather resistance. I guess we will see
Old 01-11-2013, 11:09 AM   #5
mmm Tacos
your right, bran fart on my part. i still think having it under the spring is better as when i take my antenna off I want it to look clean and flush.
Old 01-11-2013, 03:14 PM   #6
STRIKER TRD
The cooler it looks the faster and better the truck handles too
Old 01-11-2013, 03:24 PM   #7
H Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shedH Bomb is one of the sharper tools in the shed
Gender: Female
H Bomb's Tacoma Gallery
Mine is mounted on top of the spring. No logic behind why I did it that way... Your way will look much cleaner when the antenna is disconnected though.
Quick connect/disconnect for power/jump starting JMayotte 1st Gen. Tacomas 4 12-11-2012 08:36 AM
Quick disconnect sway bar Polowhitfoot Suspension 28 12-05-2012 06:45 PM
Quick Disconnect Mud Flap kit TROKITA 1st Gen. Tacomas 4 11-28-2011 06:51 PM
OBA question: Where did you mount the quick disconnect? gordynor 2nd Gen. Tacomas 25 01-01-2011 12:24 PM
Does anyone want to start making a sway bar quick disconnect? Chickenmunga Suspension 2 10-14-2010 02:10 PM
