ABS Light won't shut off
Discussion in 'Technical Chat' started by TAKoma907, Feb 23, 2013.
  1. Feb 23, 2013 at 12:42 PM
    TAKoma907
    TAKoma907 [OP] Well-Known Member
    Charles
    Alaska
    06 Tacoma
    2.5" Lift, Bilstein shocks, 10" Sub, CCFL Halo Headlights, K and N Air Intake, MagnaFlow Exhaust
    I just changed my wheel bearings and front brakes and now my ABS light is on constantly. My ABS also is no longer functioning as I now easily lock up my brakes on ice. Is this just an issue where I have to reset something? Any ideas?
  2. Feb 23, 2013 at 12:46 PM
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    Probably put too much tension on one of the speed sensor wires...
  3. Feb 23, 2013 at 12:50 PM
    SGT Taco
    Scott
    Spring Hill TN.
    Just have a shop or parts store read the OBD to tell u what one. It's an easy replacement, but they cost $75+...
  4. Feb 23, 2013 at 12:53 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
    Alright, I'll try and find a friend with an OBD reader. I was hoping I could reset it like the Maint Req light. Although, not having ABS is kinda fun.
  5. Feb 23, 2013 at 12:58 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Try this. No scanner needed
  6. Feb 23, 2013 at 2:10 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
    THANK YOU!!
  7. Feb 23, 2013 at 2:11 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    whatever you did explain it, because alot of people would like to know how to disbale ABS lol.
  8. Feb 23, 2013 at 2:26 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
    Just let me change your wheelbearings haha. Im actually thinking about leaving it off. The truck stops better, even on ice.
  9. Feb 23, 2013 at 7:15 PM
    SGT Taco
    Scott
    Spring Hill TN.
    Do the abs kill switch mod...
    Also you can try to rewire the speed sensor that is broken, I did it on a camery. Just cut the wire just above the sensor and just below the plug. Then usr some 18/2 wire and solder in place. Tape well and cover with some split loom for protection.
  10. Feb 23, 2013 at 7:22 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    OBD II scanners don't read abs codes. You'll need toyota or equivalent software.
    Is the wheel sensor plugged it? (On the bearing you replaced)
  11. Apr 10, 2013 at 10:23 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Is that the OBD II harness? Or is that something else?
  12. Jun 4, 2013 at 1:11 PM
    Brandoaz
    Brandoaz Active Member
    Im trying to diagnose an issue form this thread...
    http://www.tacomaworld.com/forum/te...ke-light-after-tire-blow-out.html#post6970128
    but came across the chart you posted:
    I jumped the OBDII and it gave me
    34
    41
    sound like left rear (34)
    and a battery issue? ( 41)
    BUT, in the chart there is an * that says, even after repair a certain procedure must be followed to reset the ABS light.
    What procedure is that?
    Also is there a way to turn of the ABS/Brake light on the dashboard?
  13. Jun 5, 2013 at 9:51 PM
    NelsonTacoma
    Tucson, AZ
    The *1 just means you need to fix the problem & the system should self clear the code. The system automatically checks for issues when you first turn the key on, if there are no issues the light will stay off. Another way to possibly ensure that the codes are cleared is to disconnect the battery for 30 mins so the computers completely shut down and lose all memory (this doesn't always work though). Sometimes you have to drive it a few miles to get it to clear too, depending upon the code the system sometimes wants to see wheel speed data to verify repair as well.
    To me it seems you need the left rear wheel speed sensor (possibly) and a new battery (possibly). I would start with the sensor & go from there.
    There is no way to turn off the abs light other than to fix the problem. The light is there to indicate a failure in the system.
  14. Jun 6, 2013 at 12:48 PM
    Brandoaz
    i pulled the sensor( much easier to unbolt it , then remove it from the wiring harness).
    Sensor was covered in light colored grease ( very clean).
    Wiped it anyway, did not attempt to insert anything into the sensor opening.
    cleaned all contacts on sensor and plug( didnt really seem dirty).
    reassembled.
    Lights remain on.
    Reset of tapping brake peddle 8 times in 5 seconds doesn't do anything.
    Is there any way to check functionality of sensor with a meter?
    What about wiring?
    Is this something that will reset immediately or take a few miles IF something was fixed?
  15. Jun 6, 2013 at 2:02 PM
    Spoonman
    Jamie
    Alberta
    You'd need to fix the sensor then clear the abs code with a real scanner. Not an OBD II handheld. Toyota or equivalent software.
  16. Sep 26, 2015 at 11:11 AM
    Brandoaz
    I just changed the sensor but the light remains on. This is normal i pressume.
    Is there a way to clear the abs code without a "real" scanner? Ive seen several things about jumping pin 4 and 13, and tapping the brake 8 times in 5 seconds, i dont want to short anything out in the OBDII if that wont work.
  17. Nov 10, 2015 at 5:19 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Did you ever fit this problem?
  18. Nov 10, 2015 at 8:56 AM
    Brandoaz
    at this point, not sure, i changed the sensor, ABS/Brake light remain on. i reid the "at home" remedies to reset sensor but that didn't work.
    Just due to more pressing issues i haven't had the time to mess with this further, but i may soon, plan was just to take it up to a Toyota dealer and see what they say and go form there.
  19. Nov 10, 2015 at 9:33 AM
    jowybyo
    Joe
    Baltimore, MD
    I'm getting code 31 and 94....I can't figure out what code 94 means.
  20. May 25, 2023 at 5:51 PM
    CheeseSauceCat
    CheeseSauceCat New Member
    The best thing to do is flash your codes so you know what to fix and then what I did was remove the dash cluster and remove the tiny twist light off the mother board on the back of the dash cluster. Problem solved. No more pesky light issues.
