VSC, 4X4, VSC TRAC Lights on
Old 02-24-2013, 02:29 PM   #1
PantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shedPantherTaco is one of the sharper tools in the shed
Location: Home: Lexington, VA Current: Pittsburgh/Chicora, PA
PantherTaco's Tacoma Gallery
Aunts 04 4runner with close to 200k miles recently started having problems, stealership said it was the t-case. Would like some opinions on what the problem is. 4x4 and 4x4 with an x over it are flashing and the vsc and vsc trac are on constantly. check engine light is on as well. heres a pic.
thanks for the help
Old 02-24-2013, 03:13 PM   #2
Toyota Technician
Ryanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shed
Ryanv's Tacoma Gallery
need codes to help
Old 02-24-2013, 03:14 PM   #3
Originally Posted by Ryanv View Post
need codes to help
yeah i told her to get an obd scanner
Old 02-25-2013, 09:12 AM   #4
BlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shed
BlueT's Avatar
BlueT's Tacoma Gallery
thanks for the help
Failure of shift motor on 4runner tcase is common. Also expensive as hell to fix it.
2005-2008 4X4 TRD Off Roads - VSC/TRAC/HAC/DAC/ALSD/ATRAC explained GP3 Technical Chat 24 02-10-2015 02:28 AM
VSC+ATRAC in place of Std VSC+TRAC w/HAC & DAC = ?????? NiceGuyEddie 2nd Gen. Tacomas 12 09-08-2013 04:42 PM
VSC OFF, VSC TRAC, skid, and check engine annunciators all just went on - halp! BenWA 2nd Gen. Tacomas 14 06-16-2011 04:53 PM
Does VSC on a 2010 4X4 mean auto LSD, TRAC? iJDub 2nd Gen. Tacomas 10 05-18-2011 11:54 PM
What is VSC and TRAC harpolith 2nd Gen. Tacomas 6 10-22-2009 03:30 PM
