2010 Insturment Lights Issue
Old 03-03-2013, 11:10 AM   #1
woode87 [OP] woode87 is offline
woode87 is on a distinguished road
Navy: Aircraft Mechanic
woode87's Tacoma Gallery
My truck randomly has these lights click on, and I can hear a *click* from the glove box area. They flick on and off (and my speedo drops to 0) as if something is loose but I don't know what it could be? Is there one fuse that controls all of these?
Uploaded with ImageShack.us
It is worth noting that I was in 2WD, "D", going about 10mph when I took this photo
Old 03-03-2013, 12:43 PM   #2
Toyota Technician
Ryanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shedRyanv is one of the sharper tools in the shed
Ryanv's Tacoma Gallery
What wiring mods have you done to the truck?
Old 03-03-2013, 12:49 PM   #3
Yellow wire mod (i double checked and it's still good) and an aftermarket stereo/amps.
Old 03-04-2013, 10:22 AM   #4
Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
Brendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shedBrendo Ballz808 is one of the sharper tools in the shed
Brendo Ballz808's Avatar
Brendo Ballz808's Tacoma Gallery
Im getting the same problem with my 05 Reg Cab
my speedo makes a clicking sounds sometimes my tach if off or don't work sometimes my speedo will be at 15 at a complete stop
whats the yellow wire mod?
Im thinking the previous owner wired something wrong on my truck
Old 03-04-2013, 10:39 AM   #5
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
It would most likely be a loose connection, or perhaps a bad relay. All of those warning lights get their power from the same source, and since they are on, it looks like you are having something telling the cluster to turn on those lights. Looking at the wiring diagram for the control of those warning lights, it appears that they are all from different modules. Since they are from so many different controls, you may have a main relay that powers those units, failing intermittently, or perhaps a major ground that is loose. Another option is a bad harness connection. I would look behind the glove box (Since you mentioned hearing a noise there) and start looking around.
Old 03-06-2013, 09:39 AM   #6
Update
I narrowed the problem down, however now I am more confused.
I just happened to adjust my steering wheel so I could try to figure out why this problem is happening (look at fuse box) and noticed that when I move my steering column - it triggers it (or fixes it).
What in there would cause all the above to happen (as well as lock out my gear selector and not allow me to start)?
2010 Tacoma Warning Lights issue starbucks 2nd Gen. Tacomas 10 06-12-2013 12:55 AM
How to remove the insturment cluster? cfrea 2nd Gen. Tacomas 4 05-10-2012 06:33 PM
2010 clutch issue rab44 2nd Gen. Tacomas 0 02-02-2012 02:30 PM
insturment cluster dim cadis10 1st Gen. Tacomas 3 02-19-2011 08:43 PM
2010 Tranny issue? brian2010 2nd Gen. Tacomas 4 09-28-2010 01:18 PM
